Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
Print unable 70 showing have cleared paper jam as in guide but machine will not respond to any buttons. paper will start but not fully take up.
  • Anonymous Mar 25, 2011
    thanks. after trying everything in the manual I had another look today and found a piece of crumpled paper jambed in the right hand side .it must have worked its way out after all my attempts to clear it. might be of help to someone else. Bob
  • 52 Answers
Some foreign object such as a clip or piece of paper may have fallen into the printhead path.
Open the cover and look for it.
Or try turning of and unplug for 24 hours. If you have stored faxes in memory make sure to plug in and power on at the 23 hour mark.
Good Luck
If this does not work you will need an authorized serviced center
You can try:
Southeast Digital Networks, Inc.
2709 Allen Road
Tallahassee, Fl 32312
850-681-9528
Posted on Mar 23, 2011
PRINT UNABLE 70
You would need to remove jammed paper opening back cover.
Nov 18, 2013 | Brother Mfc 250c Clr Inkjet P S C F Usb...
HOW CAN I CLEAR ERROR CODE 70 .Brother DCP -195C
Brother Printer is one of the best printing machine and comes with bundles of excellent features. Brother Printing machine is known for its high quality printing feature and its customer value. But sometimes user encounter various kind of problem while working with printing machine like Driver installtion and upgrade issue, Printer Set up/Configure issue, Paper Jam issue, Spooler error, Machine unable to print , Error code and so on. And being as a novice user you don't know how to fix them all issue then its recommended to get in touch with Brother Printer Support Experts for on the time assistance.
Here in this post we have mentioned about Brother unable to print 70 error message and how to fix it.
Require Sequential Steps to Fix Brother Printer Error Code 70
1. First you need to turn off the machine for few minutes then turn it ON again. If problem not gone due to turn ON/OFF process then you have to open the back cover.
2. Now carefully pull the green tab at the left and the right sides then fold down the fuser.
3. Always remember one thing there is no paper stuck inside the roller.
Note: If user doesn't find any kind of paper inside the roller then close the cover carefully. But if paper stuck inside the roller then gently remove it or close the cover.
4. Finally Turn ON the printing Device, if it shows ready it means unable to print 70 error has been fixed.
Above listed steps definitely resolve your printer error. If stil you are troubling with same error then its recommended to get in touch with Brother printer support experts at yahooemailsupport or pick a phone and make a call on toll-free Brother Printer Support Number 1-833-327-1999.
Brother Printer Customer Support Toll Free Number USA
Mar 29, 2013 | Brother DCP-195C A4 Colour Inkjet...
What cause a error report Unable to print 70? and how do I solve problem. Many thanks Susan
These mean the machine does not work due to a paper jam or some sensor problem. try to clear the paper jam. If the problem still continues after clearing the paper jam, try to clean the encoder strip (clear strip of plastic) located behind the head.
Nov 10, 2010 | Brother MFC 490cw Color Inkjet...
Dear all here i am anil kumar from india i have MFC brother printer DCP-195C but i have facing problem when i print the page the printer show print unable error 70 please solve my problem thanks...
Error 70 normally is a paper jam or something else that is stopping your print head moving correctly.
Open the covers, have a look, and after clearing the jam you must power off and on the machine.
- Dirty encoder strip
- Foreign object, such as a paper clip or ripped piece of paper is stuck in the machine
- Mechanical malfunction
The most common cause of this issue is dirt on the encoder strip.
Oct 27, 2010 | Brother DCP 165C Compact Color Inkjet...
I cleared paper jam, printer won't respond, still have error messages
turn it completely off..let it sit for the length of a cup of coffee..try it again..
Oct 13, 2008 | Lexmark E450dn Laser Printer
Clearing an error
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
mikey
Mar 14, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Nov 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Unable to print properly keeps printing on one line
Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
344 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
