Olympus P-440 wont turn on - Office Equipment & Supplies
  • 12,061 Answers
Http://www.retrevo.com/support/Olympus-P-440-Printers-manual/id/261ag413/t/2/
Above is your user manual
This is most often caused by a simple power supply fault. The switchmode controller/power conditioning circuit, inside the printer usually fails.
This isn't a real big repair. to get the very best result, what you need to do, is contact an Olympus local or head office, ask them for a referral to an authorised service center. now when at the service center, here ask for a 'Quote" for the repair, FIRST, before allowing any repair work to commence.
Posted on Mar 23, 2011
How can I clear a paper jam error?
Remove the paper Cassette.
Open the front cover to see where is paper is jammed.
Clear the paper path and close the cover
http://www.olympusamerica.com/files/oima_cckb/p-440_reference_manual_en.pdf
Mar 30, 2016 | Olympus P-440 Thermal Photo Printer
Horizontal lines on the photos
hello, have you cleaned the thermal printhead, use isopropyl alcohol, and a soft cloth
Sep 30, 2010 | Olympus P-440 Thermal Photo Printer
Olympus P-440 doesn't work with Snow Leopard. What
The first thing that you need to do is to verify if your Olympus P-440 is if it's supported by Mac OSX 10.6.x (Snow Leopard). If yes, make sure that you've installed the correct driver for Snow Leopard.
You may check the link below:
http://driverscollection.com/?file_cid=41942227668e7c7e22782bc2081
This link contains a driver for Mac OSX. I assume that this driver will work with all OSX (starting from Tiger to Snow Leopard). If this driver will not help, you may need to contact the manufacturer, and verify the system requirements of your printer.
Thank you and good luck!
Jul 22, 2010 | Olympus P-440 Thermal Photo Printer
Can't find drivers for Windows 7 for the Olympus P-440 Printer
Talked to the dudes at Olympus...won't work on a 64bit. Im in the same boat :(
May 17, 2010 | Olympus P-440 Thermal Photo Printer
Paper jam!
If the printer does not pick up paper ...
Take a paper towel and clean the two rubber pick-up rollers (grey color) with rubbing alcohol.
You can see the tow rollers when you look down (from the top) in the slot where the paper tray goes.
Apr 14, 2009 | Olympus P-440 Thermal Photo Printer
Olympus P440 Dose not work on Vista
The driver for the P-440 printer will work in Windows Vista. To install it you will need to run it in Windows compatibility mode XP service pack 2. Download the P-440 driver to your desktop from the olympusamerica.com website. Open the zip file, right click the mouse on the setup.exe file then left click on Properties. There will be a compatibility tab there. Select XP Service pack 2 and then click Ok. Connect the printer and as it goes through the found new hardware wizard direct to the folder location on your desktop for the files it needs to load the device driver.
Nov 17, 2008 | Olympus P-440 Thermal Photo Printer
Olymus P-440 dont work with Vista
I finally had time to sit and get my Olympus P-400 to work on Vista. I am using Vista 32 bit Service Pack 1.
Good thing I did this as I almost sold it!
Here's what you do: I created a new file folder on the Desktop to make this a little easier.
Using the original disk browse to the Acroread file folder, than to your specific language file and Copy the file ar405eng.exe to your Desktop in your new folder. The "eng" is for English.
Right mouse click the ar405eng.exe and select Properties.
Than select the Compatibility Tab.
Select Compatibility Mode and select "Windows 98/ME"
Also select "Run this program as an Administrator"
When I ran it it coped the .inf and DLL files to their own file. Do a search and locate files starting with "Olympus".
Got to Control Panel
Go to Printers
Click Add Printer
Choose Local Printer
Choose Have a Disk
Browse to the location where the .inf and DLL files are located when you did the search.
This installed the correct driver and I was able to print using Photoshop without error.
Hope this helps!!!!!!!!!!!!!!
Apr 06, 2008 | Olympus P-440 Thermal Photo Printer
My Olympus E-10 wont turn on and its not the battery.
Have you tried cleaning the battery contact points inside the battery compartment?
Feb 09, 2008 | Olympus Camedia E-10 Digital Camera
OLYMPUS P-440 PRINTER
uninstall your printer programme shut down your pc and connect your printer to pc then turn on your computer your computer will display that found new hardware now insert your printer cd and installit on pc and it will run.
Nov 26, 2007 | Computers & Internet
19 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
