Question about Soleus 30-Pint Dehumidifier
What setting do you have to have it on for the water to come out of hose only
    Brigadier General:
  • 4,736 Answers
The water collection bucket may have a hose tap in it. But, in your case the hose drain connection is on the side of the unit. You have to remove the cover of the hose connection, before you can connect the garden hose. Here's where it gets a little tricky, because the Owners Manual says to leave the bucket in place. However, the Troubleshooting Guide says to remove the bucket, if water is not draining thru the hose. Which to me, makes sense, because the unit can't recognize that the hose is connected, if the bucket is still installed, because it has a safety switch.
In case you have misplaced your Owners Manual, here is a link to it, that you can download and print for future reference.
http://www.natlallergy.com/uploads/pdfs/Soleus-Air-30-40-Pint.pdf
Hope this helps you solve the problem.
Posted on Mar 24, 2011
I HAVE AIDYLIS DEHUMIDIFIER#0526011 THAT WHEN HOOKED UP WITH A FLOOR DRAIN STILL LETS WATER GO DOWN INTO THE CATCH BUCKET AND NOT COMPLEATLY OUT THE DRAIN
id ck the drain hose connection for build up of fouling material , the symptom you describe usually occurs when the hose cant drain all the water the machine makes
a wet/dry vac is perfect for this (set to wet) and some even allow you to turn airflow around to blow air as well , this is perfect to clear a stopped up hose (point end into bucket)
Nov 28, 2015 | Dehumidifiers
When I connect a hose to the dehumidifier, it doesn't pull the water out and send it to the sump pump -- it goes directly into the bucket......do I need a special connection for the hose or something? ...
Patti, the problem is not the drain hose (unless it's clogged or exceeds 48" in length). The internal drain tubing to the hose connection is clogged. When this happens, water is diverted to the water collection bucket. To unclog the tubing do the following:
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connection hole and tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for water flow. It may take 10 to 15 minutes for the water to start flowing, so be patient.
I hop the helps you, Patti and thanks for choosing FixYa.
Sep 12, 2011 | Maytag M7DH65B2A Dehumidifier
Hose connected but not draining and bucket filling
I am also an air conditioning tech, with same problem and same soleus dehumidifier problem. you must remove the plug and install the drain line hose adapter. Hose must lay flat and have no "hills" for water to drain. With this done pull your drain pan out and set aside. look under right side facing the dehumidifier and you will see a small spout. Has a lip like a little tea pot. Plug that spout. I used a foam ear plug used in work shops. Now give the front of dehumidifier a slight rise on front wheels about the thickness of a pies of cardboard 1/8 to 3/16 of an inch. Now put drain pan back in an start up. The problem is the drain pan was made with very little differance in pitch between the the hose drain and the bucket drain. Remember to check your drain hose periodically and the air filter also. Good luck
Sep 09, 2011 | Soleus CFM-40 Dehumidifier
I have an Energy Star 54701. Turned on, 35 % humidity set, hose connected and ready to drain in sump hole, bucket connected. set for 6 hours. No water is draining from hose or into bucket????
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 02, 2011 | Soleus 30-Pint Dehumidifier
Turned on for 6 hours bucket in - hose connected - set for 35 % humidity. No water draining from hose or into bucket?? Please assist.
heatman101
Sep 02, 2011 | Kenmore 54701 Dehumidifier
I have a Goldstar DH504EL dehumidifier. We set up a hose to drain the machine and followed the directions to reroute the water, but even though some water is now going through the hose, the bucket is still...
Either the hose is clogged or to long (should not exceed 48" in length an be straight as it slopes down to the floor). In addition, the hose connection on the unit may be partially clogged, as well as the interior tubing. When that happens, water is diverted to the bucket. To unclog it follow the directions below.
Turn the unit OFF & unplug it.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connection hole & tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. reconnect the hose to the unit, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose for increased water flow.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helps you solve the problem & thanks for choosing FixYa.
Aug 17, 2011 | Goldstar Dehumidifiers
Hose attachment to drain water to sump pump not working. Is there some plug of some type that has to be removed to allow water to enter hose? Can not find manual.
If you hooked up the hose correctly, you had to remove the drain cap.
If the hose is longer than 5 feet, that's part of the problem. The hose must slope down and straight to a floor drain. It relies on gravity to drain.
Although you just purchased it, the hose connector and inner tubing may be clogged. This is another reason water is diverted to the bucket. Turn the unit OFF & unplug it.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connector and tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose for water flow. It may take 5 to 10 minutes for water to appear.
Hope this helps you to troubleshoot & solves the problem. Thanks for choosing FixYa.
Aug 16, 2011 | Comfort-Aire BHD-301 Dehumidifier
I have a Whirlpool Gold dehumidifier with the hose set up for direct water release into a sink drain. I assumed once you hooked up the manufacturer hose provided it would be a direct drain process and...
I have a similar Whirlpool dehumidifier and a similar problem. Have you tried setting it to continuous mode? My understanding was that it would only divert the drainage to a side hose when in the continuous mode.
Jul 20, 2010 | Dehumidifiers
Soleus 30-Pint Dehumidifier Logo
918 people viewed this question
Top Soleus Dehumidifiers Experts
jeff5may32
john h
AZBen
AZBen
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
