Question about Konica Minolta DiMAGE Z2 Digital Camera
When using the flash no matter what battery I use it drains the battery almost immediately... What can I do about that?
    Brigadier General:
  • 11,967 Answers
Sounds like a short in the flash circuit. The repair won't be cheap. Get an estimate and decide if it's worth the expense.
Posted on Mar 23, 2011
Microphone drains batteries even when off.
If you are using Nickel-Metal Hydride, rechargeable batteries, they are not designed to hold a charge for a week---just a couple of days if that. They are meant to be continuously charged or when charged, used immediately; best use for cameras/flash.
Nov 06, 2013 | Sennheiser Audio Players & Recorders
My Asus eee pc netbook runs smoothly when battery AND AC is connected. But if I only use battery, it turns off immediately even if the battery is fully charged. When AC is connected WITHOUT the batteries,...
This is a sign of a faulty battery. Try to drain the battery completely. Check if there is a button that you can press on the battery to drain its power. Drain the power and charge it at least for 30 mnutes before using it. See if this solves your problem.
If not, you have to replace the battery pack.
Hope this helps.
Jul 14, 2011 | ASUS Computers & Internet
I just purchase the Canon Power shot SX 130. Batteries are new and after a few days the camera batery light is flashing and I can't take any pictures the camera shot down. Please help.
Buy a proper NiMH rechargeable batteries (Sanyo Eneloop for example). Modern cameras will drain alkaline batteries in the matter of hours, not days.
Dec 30, 2010 | Canon Cameras
The batteries always seem to drain shortly after putting them into the camera, no matter what type or brand of battery I use. Help!!!
?? Drain as in leaking. If the camera makes the batteries leak you should contact KODAK immediately and they will make a HSE case for you. Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490 If you mean the camera is drinking batteries try these steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 20, 2010 | Kodak EasyShare C633 Digital Camera
Theft system - battery drain
Take it back to the guy that installed the alarm system cos mine runs 3 LEDs & its fine
May 03, 2009 | Pontiac Sunfire Cars & Trucks
Kodak Z1085 IS - drains battery even when camera is not on
the camera takes 1.5v to operate it
anything less the camera will shut down
recharge batteries are only 1.4v so at full
recharge it won't last long
The best batteries are litheum that have the right
volts and capacity to keep the camera going.
try turning or the camera stablizer setting...
might save your battery power.
Mar 17, 2009 | Kodak EASYSHARE Z1085 IS Digital Camera
Canon PowerShot, SD900, Using AutoFlash, pictures takes 8 seconds
It takes quite abit of power to charge the flash module. The older your batteries are, or the more drained they are = more time it's going take to charge the flash module.
It requires fresh batteries. If your batteries are not fresh, the camera will still work up to a point (that's why you can still take pictures), but it will take longer to charge the flash module.
You will be able to check this, if you have the A/C adapter. You will find that by using the adapter from a wall outlet, you'll have no problem with the flash time.
This will fix your problem, and you'll get better performance from your camera. Thanks for coming to FixYa, and don't forget to rate my solution.
Rob
Feb 24, 2009 | Canon Cameras
Digital rebel battery drain with flash only
I would suspect the batteries
Ive got an eos Rebel think its just over 4 years old
for the last year its been used every weekend for several hours 300+ pics per weekend between 2 nights I found that recently where one battery would last a night the battery was running out midway through & also taking longer to charge afterwards
2 after market replacements cost me about £10 and things are back to normal
5 years is a pretty good lifespan for a battery so its probably just getting old
Nov 29, 2008 | Canon Digital Rebel / EOS-300D Digital...
Camera Draining Battery
Lachuaeyes,
I have a different model of Olympus and I read that you did not always have this problem and you already have replaced the battery so an old battery is not likely the issue. I suspect you might have something that is draining that was not set in the past. I keep my batteries longer by not using flash most of the time. Is there someone new using the camera that perhaps leaves it on longer than you do after finishing, perhaps uses flash longer? Is there a setting for auto shutdown that has been changed to not turn off as fast as it used to? If none of these I wonder if the flash is requiring more energy than in the past.
Could you tell me if the battery is draining even if you don't use it or is it only if you are using it does it drain faster.
Another possibility is that the charger is not charging so well as it used to but I suspect you leave it in long enough and more.
If you have the ability to check the output voltage of the charger with a multimeter you would be sure it is really putting out enough volts to charge fully.
Please let me know if you have further questions.
HarryF
Dec 21, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Very short battery life.
You could check the manual and/or the Tech support team. But in the main that is what cameras do - eat batteries. Best to get rechargeable sets and a charger I have 3 Li-ON batteries and a charger for my Oly 300 and six sets of 4 AA Ni-Mahs and charger for my E10
Jul 11, 2007 | Konica Minolta DiMAGE E500 Digital Camera
Konica Minolta DiMAGE Z2 Digital Camera Logo
21 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
