Question about Dehumidifiers
Honeywell HDH-131 is sucking up a it of water but it takes forever. Cold air blowing out pretty hard. I think the unit became de-programmed and I can't find my manual to reset it.
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on May 27, 2011
Why is it blowing cold air?
A dehumidifier should blow cold air Carole. It takes in warm moist air, chills it, condenses the water out of the air and returns it chilled and dry to the room. That is the function of a dehumidifier. They often have the function of an air conditioner and blow cold air out of one outlet into the room and hot air out of the window via a venting hose. If yours is just a dehumidifier, it is working as designed
What were your expecting a dehumidifier to do?
Jan 15, 2016 | Amcor Dehumidifiers
Model HDH 165 honeywell dehumidifier owners manual
I just got one from a friend of mine and we dont have a manual so i went to the honeywell site typed in the code HDH-165 and it comes back with nothing. kinda frusterating as i need my place to be cool and was told by gettong one of these it will take the mold smell and tthe heat out.
Jul 24, 2013 | Dehumidifiers
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
Unit is running & blowing cold air. Unit is not sucking any moisture out of the air.
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled unit, set the knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helped you.
Jul 18, 2011 | Goldstar DH304 Dehumidifier
I have a Honeywell Dehumidifier - Model HdH-131 - it has iced up and isn't working properly -
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
May 09, 2011 | Dehumidifiers
The dehumidifier is running, sucking air in at the back and blowing out through the front grill, but over a number of days is not actually collecting any water in the water tray.
The quantity of water depends on the relative humidity in YOUR air.You may need to have the unit checked to see that the mechanical portion is working....
Feb 20, 2011 | Dehumidifiers
Need manual for honeywell dehumidifier model hdh 131
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 30, 2010 | Dehumidifiers
My soleus CFM40 has stopped dehumidifying. Just blows cold air. I think the heat element that dries the air stopped working. Do yo agree?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Mar 02, 2010 | Soleus CFM-40 Dehumidifier
Blows cold air,but no condensed water
To condense the water (cold side) the air should be warm.
Sounds like coolant leak or compressor problem; if so, time for new unit.
Dec 04, 2009 | DeLonghi Dehumidifiers
Is it possible in aircon to used it with no compressor??
Nothing in air conditioning is new. It has been done for many years.
There are three types of "compressorless" refrigeration that I can think of.
1. ) swamp coolers or evaporative coolers - these work on the process of adiabatic saturation in low humidity environments. Evaporating water removes energy from the air, makes it cooler and more humid. This is a win-win when the air is very dry, but the process doesn't work well in humid environments, were water evaporates less readily.
2.) Peltier junction solid state coolers. These are essentially a thermocouple driven in reverse. Conduction between the hot and cold plates is hard to control and at low voltages these devices need a lot of current. These units are not as efficient as mechanical refrigeration.
3.) Absorption refrigeration cycle. In these systems a solution of ammonia in water (or water in a lithium bromide brine) is used. Heating the water (or brine) drives out the ammonia (or water vapor) and takes the place of the compressor in the cycle. This cycle is useful if you have a source of waste heat. You essentially recover the energy in the waste heat to run a refrigeration unit. A few demo units have used solar energy as the heat source, but I don't think this is common
Sep 18, 2009 | Dehumidifiers
Dehumidifiers Logo
295 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
