Question about Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator
The door open signal comes on & the temp Light Flashes
  • 29 Answers
Is the unit cooling properly? Check the freezer for thawed out food. Normally this is a warning sign that the unit is malfunctioning.
Posted on Mar 23, 2011
Mde3500 Electric Dryer will not heat
it sounds like the door switch itself is good but has a poor connection after the switch. That would explain why the momentary light flashes. The heating element will not start unless the door switch is sending a constant closed signal. Check your wiring & control board.
May 02, 2014 | Maytag Dryers
Lights Out and Door Open Indicator Flashes
The problem is above the doors at the switch, the unit can't see the switch opening (closing the door opens the switch). The linkage is where the problem is, the light go out to protect the fridge from getting too warm and the lights are remaining on after you close the door.
I hope this helped. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 22, 2013 | KitchenAid Refrigerators
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
The clean light will not stop blinking so the normal cycle will not run
From another link, clean light flashes 7 times. Turn off breaker for dishwasher, wait 5 minutes, turn back on. with dishwasher door open, push high temp, energy save dry, high temp, energy save dry, then close door, open door, press cancel and then Normal wash cycle. Dishwasher Starts!!!!!! Save myself several hundred $. Was about to buy new one from Lowes!!!!!! Thanks everyone!
Feb 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Cleaning Light flashes 7 times then repeats 7 flashes again. Cant find model #.... About 6 years old.. Thank you
342f192.jpg techbuster
  • Rank: Guru dishwashers_small.png
  • Rating: 92%, 2877 Votes
  1. Crack open door
  2. Within 3 seconds push Hi-Temp Scrub, Heat Dry, Hi-Temp Scrub, Heat Dry
  3. Close and latch door
  4. Press Cance
Try the above steps and also check the video in link given below to know detailed explantion on what the light means
http://www.youtube.com/watch?v=Hv7xOaucH7I
Jan 19, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Normal and heavy cyle lights wont come onwhen selected What is happening?
do you get 7 flashes of the clean light? if so, do this: Open door press: high temp, energy save, high temp, energy save, close door, open door, press cancel. then run as usual.
Jan 15, 2011 | KitchenAid 24 in. KUDP02FR Built-in...
Kitchen aid dishwashers model kudi1o1ilbl6 won't function. Cancel light flashes 7 times pauses and flashes 7 times repeat for ever. killing the power did not reset. Advice?
open door, press in rapid sequence the following keys: hi temp scrub, energy saver dry, hi temp scrub, energy saver dry. Close the door until it latches, then open it and depress the cancel key. The lght should clear. It's a beautiful thing.
Aug 15, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator Logo
104 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
