Question about Garden
NO start with no spark. Tried changing plug. NO change
    President:
  • 1,545 Answers
Spark plug must be grounded against the engine to be checked. If it is truly a no/spark condition, then the next thing to check is the "dead-man" switch if it is on a pushmower and then check the ignition module air-gap. That is the distance in between the legs of the coil and the magnets in the flywheel. Different engine applications (you did not say) are set a few thousandths different but a good rule of thumb is closer is better. Set the air gap at .008"-012" or about the thickness of a standard sized business card. If this doesn't produce a spark, then the ignition module is possibly bad.
Posted on Mar 23, 2011
And changed gear from neutral to park and tried starting. but it won't start again when i tried. is it ignition box problem or anything else ?
You can check the ignition module by pulling a spark plug wire and inserting an old spark plug. Any plug should do, just make sure to rest the base of the plug to a good ground source. Crank the engine while someone looks at the plug for spark.
Aug 09, 2014 | 2001 Toyota Prius
After changing plugs, air Filter , oil filter and fuel filter, I tried starting it and now its misfiring.
You most likely need new Spark Plug Wires. When you change your Spark Plugs, it is always a good idea to throw some New Spark Plug Wires in with them.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 12, 2011 | 2000 Mercedes-Benz C-Class
Have a 1985 buick centruy with a 2.5 seems like its loading up with to much fuel wont start.I have spark timing is good, compression good, and changed the temp sensor. tried a different maf sensor(used)...
If you have spark, and the timing is good, you are either not getting enough fuel or there is not enough compression. If you checked the spark from the spark plug wires and got a spark, try changing the spark plugs. The spark from the plugs may be too weak to ignite the fuel.
Have you changed your fuel filter? This is a very common cause of a no start condition. Have your fuel pressure tested to ensure you are getting the correct amount of fuel. Also, you could try replacing your Fuel Pressure Regulator.
Feb 17, 2011 | 1985 Buick Century
Attempted to try and change out the cover gasket now no start
I am going to assume you pulled the spark plug wires when you were working on this. Make sure you connected the right wore to the roight spark plug
Feb 20, 2010 | 2001 Dodge Caravan
2002 honda civic ex won't start
If a defective spark plug was found, it can destroy the secondary winding in the coil pack for that plug. Change the plug wires too.
Jul 28, 2017 | 2002 Honda Civic
Fiat Sicentio 1.1 (02 plate) problem after changing spark plugs
check spark plug gaps are set correctly and that leads are in correct order if you took all leads off at same time its easy to mess up just one or two
Nov 08, 2008 | 2007 Fiat X1/9
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
