Question about HP OfficeJet 6110 All-In-One InkJet Printer
Does my printer give a confirmation after faxing is completed?
  • 604 Answers
It is capable of doing a report, but you have to go into the menu to tell it to print a fax report. It is usually off by default, because most people can tell if the fax went through (and it will say so on your display) if the fax fails that is when a report it usually printed (by default). If you really want the fax send report go into the menu and step through the levels till you find "reports" then click on "print fax reports"
Posted on Mar 23, 2011
  • HP Master
  • 1,679 Answers
Normally if i fax is sent, it will just give a message as Fax sent or it wont give any error.
But if you want to get a confirmation whether the fax is sent or not, you can print a fax confirmation page on ever fax sent or received or both.
Press the SETUP button ( menu )
Scroll till you find Print Report - Press OK
Scroll till you find Automatic Reports Setup - Press OK
Choose Send Only - Press ok
Regards,
Ron
2 Suggested Answers
agnelkj
  • 210 Answers
SOURCE: How to print fax confirmation
hi,
from the main menu on the printer scroll down to "fax setup" or "advanced fax setup"
you have the option inside it.
thanks and regards
agnel
Posted on Mar 18, 2008
Dell 1815dn Fax confirmation?
U CAN DO A FLEA POWER . \
1. restart the system ,
2. turn off the power / scan/ fax ,
3. unplug all the cable to the system and wall socket and then wait for 20-30 seconds .,
4. connect all the cables and give a try it should work.
Oct 20, 2014 | Dell Printers:Dell MFP Laser Printer...
Can,t find if fax was sent
Goto to the set-up in the software on the machine and select to have the fax print you a confirmation page, upon successful completion of fax being sent. That will fix your problem for the future, as for right now. There might be an option to print out all the history of your machines transmission that might tell you. But it wont give you a positive confirmation, will just show you the transaction. Good Luck!!
Jun 13, 2012 | Dell 968 All-In-One Printer
No FAX status confirmation printed.
go into the fax settings (or setup) on the printer and make sure it is set to give a printed report after each fax reguardless of wether it goes through or not..
May 19, 2010 | Dell 962 Photo All-In-One InkJet Printer
I need fax confirmation sheets printed when I fax from my HP Office Jet 8500. How do I get them to print?
on the printer itself --> press the setup button--> use the arrow keys on the printer and move to print report option --> press ok when you select print report--> Find out fax confirmation option and press ok --> turn it on.
If you do not find the Fax confirmation option under print report then find it under Tools option.
Press setup on printer --> press arrow key on printer and finid tools --> under that try to find the fax confirmation option.
once you switch on the fax confirmation option on the printer. every time you send a fax you will receive a fax confirmation also.
May 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Confirmation page shows zero pages sent. Is there a way to set to show the number of pages sent
I would first test a fax to see if it completes on your end then is received on it's entirety on the receiving end. Then print a fax transmittal report to confirm. Once that shows success, print your polling fax report and verify.
If it says zero pages sent, chances are the fax failed.
Jan 14, 2010 | Brother IntelliFAX 4100e All-In-One Laser...
How do i get my fax machine to print out confirmation with 1st page faxed
go into you fax options just look for conformation send or confirmation on fax error you sould be able to find those options in the general fax setup.
Oct 12, 2009 | Office Equipment & Supplies
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these
instructions to enable fax confirmation before sending any faxes. Select either On
Fax Send or Send & Receive.
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send &
Receive
Prints a fax confirmation report for every fax you send and
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Not printing a fax confirmation sheet on send.
when i fax there is no confirmation sheet that prints..........help!!!!
Jul 31, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
hi,
thanks and regards
agnel
Feb 03, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Printing confirmation page after completed fax
If you have the operators manual (it may be in the back compartment of the machine), look in the index for "fax parameters", then "fax reports".
Nov 30, 2007 | Minolta DI-2010F Copier
HP OfficeJet 6110 All-In-One InkJet Printer Logo
315 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
