Question about Poulan Pro PRRT900 17Inch 205cc Briggs Stratton 900 Series Gas Powered C
I have 2 poulan pro 900 series tillers and they are fairly new anyway when I engage tines they work fine until they hit dirt. then they stop and have a loud clicking noise. I'm sure that they are more than likely stripped out but can they be repaired and if so how ?
    President:
  • 3,074 Answers
If your tiller is one that has power to the wheels and the tines at the same time ... are the wheels going? If it is one with no power to the wheels, are the belts engaging?
Posted on Mar 23, 2011
Tines do not move in my poulan PPB2000T cultivator attachment
PPB2000 more than likely has stripped a gear in the gearbox. The drive cable is probably ok. Tines are driven by a worm gear and brass gear. Internal parts of gear box not available.
jas
Apr 24, 2012 | Poulan Cultivator Attachment
I have 2 and they are fairly new anyway when I engage tines they work fine until they hit dirt. then they stop and have a loud clicking noise. I'm sure that they are more than likely stripped out but can...
You might have just sheared a shear pin that's how some of those are designed. Check around the shaft area that connects to the engine you might find that a pin is sheared if so, pound out and replace. Sometimes also called shear bolts. Good Luck...
Mar 23, 2011 | Poulan Pro PRRT900 17Inch 205cc Briggs...
I have apoulan pro prrt850 17 inch rear tine tiller. When I took it out of storage, it started great but I could not engage the tines. The lever that moves the transmission into forward, till, or reverse...
If the gearbox has a fill plug, remove and let it air-dry or blow compressed air into it to help dry. Then, get some PB Blaster aerosol penetrant/lubricant from the auto parts store and spray as much as you can ito the box. Let is soak 24 hours or so and THEN come back to it and see if you can get it unfrozen.
Mar 17, 2011 | Poulan Pro PRRT900 17Inch 205cc Briggs...
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Troy bilt horse pto clutch will not disengage
The problem is lack of lubrication in the pto coupling. Losen the two swing bolts carefuly,block the front under the motor. Separate the tine transmision from the housing and grease both sides with as much grease as you can work in. Work the lever as you do this. Should fix the problem.
Jan 17, 2009 | Troy-Bilt Pony Garden Tiller
Poulan Pro PRRT900 17Inch 205cc Briggs Stratton 900 Series Gas Powered C Logo
346 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
