Question about Poulan Pro PRRT900 17Inch 205cc Briggs Stratton 900 Series Gas Powered C
I have 2 and they are fairly new anyway when I engage tines they work fine until they hit dirt. then they stop and have a loud clicking noise. I'm sure that they are more than likely stripped out but can they be repaired and if so how ?
  • 718 Answers
You might have just sheared a shear pin that's how some of those are designed. Check around the shaft area that connects to the engine you might find that a pin is sheared if so, pound out and replace. Sometimes also called shear bolts. Good Luck...
Posted on Mar 24, 2011
My craftsman 5hp tiller hit large rock, tines stopped, loud noise followed and now pull string won't budge. Why?
most tillers are equipped with a shear pin down by the tines. for this reason. if you hit something it will shear the pin and not do damage to your machine. it don't sound like that happened here. make sure the tines are disengaged. if the rope wont pull it may have sheared the flywheel key. there are videos on you tube that will show you how to take off the cover, the flywheel and check to see if this has happened. it may have locked the engine up at the worst scenario.
Mar 30, 2016 | Craftsman Garden
New tiller makes grinding noise when trying to run tillers
if it has a clutch
most small units just run a dog that you engage with a swift motion at low idle speed of the motor
have the tillers free above the dirt so they can turn with out any load to inhibit the dog engagement
May 20, 2015 | Garden
I have 2 poulan pro 900 series tillers and they are fairly new anyway when I engage tines they work fine until they hit dirt. then they stop and have a loud clicking noise. I'm sure that they are more than...
If your tiller is one that has power to the wheels and the tines at the same time ... are the wheels going? If it is one with no power to the wheels, are the belts engaging?
Mar 23, 2011 | Poulan Pro PRRT900 17Inch 205cc Briggs...
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Engine stalls when engaging cultivator tines
im 99 percent sure all you have to do is get the carburator cleaned out.
Jun 28, 2009 | Troy-Bilt Garden
Tines wont turn /disengaging type grinding noise
its possibly the gears inside the box they are spider gears & wearout on those they are great machines but the gear drives are weak most of the time or the belt could be slipping
Jun 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have a Troy-Bilt PTO Horse (Horse III) 8HP TINES
The tines are very close to the housing and sometimes you do get rocks hitting,as for the dirt it should have side panels to keep the dirt in place.
May 07, 2009 | Garden
Troy bilt horse pto clutch will not disengage
The problem is lack of lubrication in the pto coupling. Losen the two swing bolts carefuly,block the front under the motor. Separate the tine transmision from the housing and grease both sides with as much grease as you can work in. Work the lever as you do this. Should fix the problem.
Jan 17, 2009 | Troy-Bilt Pony Garden Tiller
Poulan Pro PRRT900 17Inch 205cc Briggs Stratton 900 Series Gas Powered C Logo
197 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
