Question about Canon I960 InkJet Photo Printer
I've tried several "fixes" and none have worked so
You can try reseating the print head.
Click on Service and Support, then type in 5 flashing lights. Click on the first result, then the first on the solutions list.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i960_series#ServiceAndSupport
Posted on Mar 23, 2011
Will not print cyan
The cyan print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked cyan print nozzles. Also check the cyan cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced. NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Canon I960 InkJet Photo Printer
I have a canon i960 printer. It won't print blue. All other colors work fine. I've replaced the ink, downloaded new drivers, run the clean print head utilities, both regular and deep cleaning. What do...
I would guess that the printhead is bad. Google cleaning printheads or get a new one. Sometimes , not always you can clean the printhead instead of replacing. (take out and clean by hand)
Apr 07, 2010 | Canon I960 InkJet Photo Printer
On my ip2000 the power light flashes green then amber and turns itself off
Canon PIXMA IP2000
You may RESET the printer code first if you like or do it after you clean the pad
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
Dec 01, 2009 | Canon i850 InkJet Photo Printer
My canon i850 printer head will not move. When I turn the printer on I get a green light followed by 5 amber lights then it alternates 1 long green followed by a short amber,short green, short amber and...
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Nov 15, 2009 | Canon i850 InkJet Photo Printer
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Vista compatibility with canon i960 printer
Here is a link to the updated drivers for Vista. You will see in the first section where you can select your operating system (OS). Click the down arrow and select Vista. Now in the box called "Drivers" click on the red .exe file. It will display a new page. Scroll down to the bottom and click on the "I agree" Button. This will start the download process. Click Run, wait for it to download and click run again. This will start the install process. This should fix your problems.
Jun 27, 2009 | Canon I960 InkJet Photo Printer
Canon i960 qill not put ink on paper
I called Canon. I also had green 1 flash and amber 1flash everytime I turned on the printer. That right there indicates an elecrical problem. The flashes mean it needs serviced and with it not printing now means it's not wirth fixing, out of warranty. Canon did offer a code for reduced price new or referbished print from them.
May 27, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Stopped printing mid page. Wouldn't eject. Now it won't even switch on properly
if you read the number of green and amber flashes that the machine makes i can tell you the problem and suggest what to look for. i am a certified Canon tech for this product. there are Canon repair center all over the united states that can repair this printer for you. or you can let me know the number of flashes and i can help you. let me know
Jan 04, 2008 | Canon I960 InkJet Photo Printer
Canon I960 InkJet Photo Printer Logo
old marine
old marine
