Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
My Whirlpool Duet washing machine's front panel lights quit working and now it will not run
  • gabe_t
    gabe_t Mar 23, 2011
    What is the model number from inside the door?
  • btison2005 Mar 23, 2011
    It's WFW8300SW02
  • 29 Answers
Make sure you still have proper voltage at the plug. try plugging something else in. If voltage is good you most likely have a bad electronic control, or user interface board.
Posted on Mar 23, 2011
  • 1 more comment
    I have replaced the interface board, so I guess I need to replace the CCU. Would that fix it?
  • gabe_t
    gabe_t Mar 23, 2011
    thats what i would do. also look for the trouble shooting guide inside the washer on the walls, it will give you some tips to go by
    Thanks, I'll try that
How can I unlock the door to my Whirlpool Duet washing machine?
try this link..Pull down on the bottom panel and pull it away from the washer. Reach through the open panel and up to the door lock. Find the release ring below the locking mechanism. Pull down on the ring to unlock the door.
How to Unlock a Whirlpool Duet Washing Machine ' Home Guides ' SF ...
homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html How can unlock the door to my Whirlpool Duet washing machine Google Search
Dec 12, 2016 | Whirlpool Washing Machines
Duet GHW9150P Front Load Washer: front load whirlpool washing machine runs fine unt...
You can try this:
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryer quit heating runs fine it is a gas dryer
Is the pilot light or "stricker" working when you start the unit.. Is it getting good supply of gas?
Mar 12, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I have a Whirlpool duet washing machine. We had a
Unplug the machine.
Remove the lower front panel.
Reach your arm up inside on the door latch side. Feel for a pull ring and pull it to release the door.
Feb 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light come on and stay on, machine not running
take a good look and read on your control panel i don't remember which button you need to hold for 3 or 5 second to lock unlock control panel. it is also called child lock system.
May 21, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Duet whirlpool ghw9150pwo
Press & hold the button on right of panel 'end of cycle' for 3 seconds, the light will go off. Child lock. <It will come on again if you dont vote me nice!!>
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer duet TH
Your problem could be the control board or control panel. Most of the cases it is the control panel. I replaced the entire panel and it works like new. If you can determine what the problem is, you can save yourself a lot of money by doing the repair yourself. Either one is quite easy to replace. Good luck.
Jul 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Old whirlpool washing machine won't run.
if no lights suspect main control bd remove rear screws in top panle remove top by sliding towar back control is along rear
Jun 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
