Question about Riccar Sewing Machines
My riccar 9600 sewing machine won't pick up the bobbin thread
landsend
  • 1066 Answers
SOURCE: Brother sewing machine vx1120 Ithink won't pick up bobbin thread
have you tried other thread and a different bobbin?  The tension screw on the bobin case could be too tight.
Posted on Mar 11, 2009
mohammed387
  • 1952 Answers
SOURCE: bobbin problem
Remove the race cover and jiggle it out. It is only stuck in there with thread.
O
oil the machine first. Then, determine whether or not you need any parts at all.
Posted on Jun 25, 2009
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
Mongo32
  • 111 Answers
SOURCE: singer sewing machine, needle will not pick up bobbin thread?
needle in backwards?
Posted on Aug 23, 2009
  • 96 Answers
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Posted on Dec 13, 2009
I have a Riccar 500FA. The upper thread will not pick up the bobbin thread. I have oiled, cleaned, checked the needle installation, the bobbin installation and the needle is brand new.
needle/hook timing needs adjustment
accredited service agent can fix or any sewing machine service shop should be able to do the job
Jul 30, 2017 | Riccar Sewing Machines
I have a Riccar 706. I can't get the upper thread to pick up the Bobbin thread. What do I need to do?
Install a brand new needle (confirm it is installed facing the correct direction).
If it still doesn't pick up the bobbin thread, the machine is probably out of time. Search for sewing machine timing or take it for service.
Jun 01, 2017 | Riccar Sewing Machines
My machineis not pickingup thread underneath not sewing
Install a brand new needle and verify it is installed correctly.
If it is still not picking up the bobbin thread, then most likely the machine is out of time. Search for sewing machine timing or take it for service.
May 25, 2017 | Riccar Sewing Machines
Need manual instructions for Riccar 2910 need help with bobbin, threding machined and tension setting and bobbin holder.
You may be better off going to google and search "riccar 2910 manual" That way you can follow their detail dorections rather then someone elses and it confuse you. Usually the PDF versions have pictures with it :-)
Apr 07, 2016 | Riccar Sewing Machines
My riccar 1900 won't thread; needle to bobbin
First make sure the bobbin-winding spindle (located on top of your machine) has been pushed back to the left for sewing.
If it is not in the correct position, the needle will not go down and pick-up your bobbin thread.
Next make sure your needle is inserted correctly, with the flat side facing back.
Also, make sure your bobbin is in correctly
the upper tension disks of your machine are threaded correctly.
Make sure the presser foot is up when seating the thread through the upper tension.
Turn the handwheel towards you only and hold the needle thread lightly.
If this doesn't help solve your problem, the machine may have a timing problem.
Jan 18, 2016 | Riccar Sewing Machines
Riccar stretch 500fa Needle won't pick up thread from bobbin
Check to make sure you are using the correct needle for the machine, that it is a brand-new needle, and that is installed facing the correct direction. Other than that, it's quite possible the machine was knocked out of time and needs service.
Apr 07, 2017 | Sewing Machines
Will not pick up bobbin thread
you might check your needle to see if it's damaged
make sure you have a least a 3-4 inch thread tail for top & bobbin
try holding the top thread tail & manually move the handwheel on the right side of the sewing machine to lower the needle to the bobbin area & see if that works.
make sure there is no lint or loose threads in bobbin area
Sep 24, 2010 | Riccar Sewing Machines
How to thread a bobbin for the Riccar 2950 model
Here's a manual for the Riccar 2910, it should be similar to your machine.
http://www.riccar.com/ftp/whitepapers/2910-Owners-Manual.pdf
Threading is on page 13 and 14 of the manual, I think, Have a browse through it. Hope this helps!
Aug 29, 2010 | Riccar R650
Sewing Machines Logo
128 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
