Question about Sharp LC-13SH1U 13 in. LCD Television
My Sharp LC-13SH1U Immidiately turns off within 5 sec after ON (Sharp Aquos LCD 13")
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 1779 Answers
SOURCE: power supply bad on Sharp Aquos LC - bad board - schematic to ID?
Buy the green light going on means Standby is ok. Next, would be to locate the plug coming from the main board to the power supply and find the post that says PO which means power on. With your meter on that post, press the power button as see if the reading goes High, if it does then the main board is able to turn on the power supply. Next, find the plug on the power supply that goes to the inverter( the long board on the side) remove it and see if you have 24 volts coming out of the power supply when you press the power. If you do, then the inverter board is bad, if you don't have 24 v, then the power supply is bad. There are NO diagrams available for these set other than a flow chart if you can find one. A regular svc tech does'nt need a manual for these anyway.
Let me know how you do Kathy ?
Posted on May 17, 2009
  • 10865 Answers
SOURCE: I can't find the owner's/TV manual for Sharp AQUOS
http://www.sharpusa.com/files/tel_man_LC46D43U.pdf
Posted on Jun 04, 2009
freelander72
  • 124 Answers
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
ps3 signal is 1080p you need a 1080p tv for it to be compatible.
Posted on Sep 17, 2009
Testimonial: "Thanks"
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Picture but no sound on two cable channels. All
Make sure under the Audio Menu that you have SAP turned OFF
Jul 09, 2009 | Sharp Aquos LC-13S1U-S 13 in. EDTV-Ready...
Sharp LC-13SH1U shuts off after a few seconds
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 17, 2017 | Sharp LC-13SH1U 13 in. LCD Television
Sharp aquos lc-52se94u green screen
If it it new, take it back. The product is not working properly.
Apr 30, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Cable/Analog Icon on screen
Usually the DISPLAY Button on your TV remote will toggle through several different functions: 1 sec, 5 sec, Always on..... Press button until display on TV is off. Or see if there is an ON SCREEN DISPLAY portion in the TV Menu and turn it to off if you have not checked that already.
Apr 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Missing Audio
your remote should have a audio setting button to go from stereo/mono/sap. Also, there should be a setting within the menus... you just have to find it.
Dec 16, 2008 | Sharp Aquos LC-13SH3U 13 in. EDTV-Ready...
What are the best picture settings for the 52" Sharp Aquos LCD
I'm happy with:
backlight +16
contrast +40
brightness +1
colour -13
tint 0
shaprness +2
although I found this setup but haven't tried it yet
backlight +5
contrast +24
brightness -7
colour +50 (review I found didn't say + or -. Try both
tint 0
sharpness -5
Len
Nov 30, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-13SH1U 13 in. LCD Television Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
