Question about Car Audio & Video
I can not figure out how to eject CD's from the head unit that was installed in a car that was given to me.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
What kind of radio is it? Is it the stock radio? If so, what kind of car is it? If it is an aftermarket radio, what make and model is it? Is it a single disk player or an in dash changer?
Posted on Mar 24, 2011
Hey guys, I've just installed a CD changer in my car - having some difficulties getting it to work. After some Googling I came across this forum so I figured I'd see if any of you guys know where I'm...
there should be a small connector on the changer itself for the power ground and remote wire for power to the changer unit. the cord coming from the unit to the changer doesn't supply this power and this is why it wont eject and also your head unit wont recognize it until it gets powered up and able to communicate with the head unit and then it will show up as a selectable source when switching between sources of music. check the back of the changer for a small connector containing 3 or 4 pins and you should have a connector with the corresponding wires coming from it to plug into this spot after connecting the wires properly. if you bought it on ebay it is possible you didn't get this piece which is critical when connecting this changer.
Apr 03, 2011 | JVC CH-X1500 12-Disc CD Changer
How do you remove cd's from a six in dash changer...it will not play or eject the cd's
hi,
It sounds like the CD rack or cartridge inside the head unit has jammed. The only way of getting them out is to remove the 2 Din head unit from the dash/console,due to each CD being lifted up into the eject position and ejected separately.
If you got the tools you can dismantle and remove them from the head unit yourself. Hope this helps, let me know ow you get on.
Apr 04, 2010 | 2004 Honda Accord
Cd changer won't play, load, or eject
Had the same problem on our 03 yukon (not the changer but the main head unit) - have a 3rd party waranty and they replaced it. You can get the part for less than 300$ and it's easy to install.
Jul 04, 2009 | 2007 GMC Yukon XL Denali
1995 Explorer 6 cd changer - how to manually eject cartridge
No there is none you have to hook up power to it then press eject.
Jun 27, 2009 | Panasonic CQ-DPX33 CD Changer
Pioneer DEH-2150 : CD Ejection switches off the Stereo
hi rolls
when there is no CD in unit hold the source button to turn unit to actual on position (when you insert a CD is it self guided once you push it to a certain point or does it just self guide instantly) if you sort of push it in a bit and unit turns on its because the pioneer function says to itself i need to be on so it will play for you but once you eject the CD the unit says time to turn off the solution i recommended should solve this if not let me know and ill figure out another step
hope i was able to help
Feb 14, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Cd shuttle ejects when power to head unit is turned on
Hi Adam,
Since you've been trying things for so long, you may not mind another, unless you've tried it already.You'll need someone to help you.
Try using a volt meter on the main power to the changer. (If the changer is din mowered only, this can't be done) and when toy power up the head unit by ignition or other method, read the voltage on the main power wire (yellow?). Tell me what it shows. Also, the "turn on" wire for the unit is usully in with the data cable to the unit, and won't be able to check that.
Also try to read BOTH the acc AND the power wire on the head unit while turning on.
When you read the voltges, make sure that you use the ground ON THE CHASSIS of the componant that you are checking. "Maybe" you have a voltage variance like you said d to a weak ground at one of the units? I'm just troubleshooting as I would if you had brought it to me. Let me know again. Thanks.
** Note- Have you actually reset bothe the head unit and changer?
Larry T
Winona Lak, IN
Jan 27, 2009 | Blaupunkt Louisiana DJ32 Cassette Player
CD will not read or play....ejects ;;ERR message flashes Help
try different KnownGood cd and if still an issue your head unit needs repair internally .(not worth it)
Nov 24, 2008 | 2000 Chevrolet Silverado
JVC Car Stereo
The head unit should have two separate +12V connections: One that goes to a switched 12V power that is switched on/off via the ignition and one that is always energized at +12V. If the head unit's switched +12V lead is not connected, the unit will not turn on (except for when +12V is first applied to the "always on" lead, in which case it will immediately eject the CD). Please respond if this is not the issue. Hope this helps!
Mar 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
Unable to eject cd magizine. Error 2
power off. open the cd changer unit. look for the motor that, when turning, performs the eject mechanism. now turn this motor by hand in the proper direction until cassette is fully ejected.
Jul 22, 2007 | Clarion DC625 6-Disc CD Changer
Trouble playing JVC KD-S580
i have the same problem in a 2001 mercury cougar. i got power all the way to the back of the radio from the ignition (red) and constant (yellow) wires and the ground wire is good. Think the head unit might be screwed the fuses are all fine. not sure though
Nov 11, 2006 | JVC KD-S580 CD Player
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
