Question about Kenwood Car Audio & Video
My girlfriend dissconnected the battery in my car and she put the deck back in lock mode. Trouble is she forgot the button that you push after she enters the code
    Top Expert:
  • Kenwood Master
  • 81,400 Answers
If you can't remember the lock out code then you must contact the manufacturer for an override code, we can't supply that. They will most likely require proof of ownership. Thanks
Posted on Mar 23, 2011
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
A few weeks ago I tried locking my iPod during school. I put the passcode on so when i pushed the top button it would lock. It never locked so i forgot about it. Now I shut the iPod completely off and I...
Connect your ipod touch to your computer and make sure itunes is open. Hold down the power and home button for 10 seconds. After 10 seconds only release the power button and keep holding the home button until your itunes says it found an ipod in recovery mode. Then restore your ipod by clicking restore on itunes, or restore to a backup you might have made, but make sure it is before you had the passcode, otherwise it will reload the passcode lock.
Hope this helps!
Please rate and vote for me if this helps!
Apr 24, 2011 | Apple iPod touch
I need to unlock the password to get into my toshiba satellite a-65. I forgot the password for right after I turn it on and need to reset it.
Is it you computer is locked or your windows is locked.
It kinda easy.
The first: if computer is locked you have to find you cmos battery in your computer and remove it, remove the big battery and remove power.
push the on button, wait 3min and put back all batteries and other power supplies.
when powering up, go into the bios and remove password enable to disable, reboot, happy computing
The second, if windows is locked, as you are booting up into windows use F8 a few times. this will get you into safe mode. Go onto contro panel and then user and change password
reboot,happy computering
Aug 03, 2010 | Toshiba Satellite A65-S1762 Notebook
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
Lift door on back will not unlock. Grinding noise
sounds like the door lock actuator is frozen and wont unlock,you will have to get the gate open to replace the actuator,you will have to remove the paneling to get inside the door,then dissconnect linkage to actuator,then make sure linkage to latch is free and not frozen,then double check the actuator while dissconnected, hit the lock/unlock button and see if the actuator moves it should not but will make alot of noise.
Apr 12, 2010 | 2000 Jeep Grand Cherokee
Player experienced static shock from vinyl handbag, player turned off and will not turn back on. Feels warm on screen surface.
1: Remove the back and check and see if the battery isn't fully connected
I put a folded peace of paper and put it on top of the battery also push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screen, Black screen Blue ring ) and put the back on.
2: RESET: Go into the settings and scroll down to reset all, push center button, scroll to yes, push center this will restore factory settings.....
3: Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.
This is what it states in the manual for the 260 sansa Page 29
4: Recovery Mode also resets system settings when unplugged... lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software
Apr 05, 2010 | SanDisk Sansa e260 MP3 Player
I bought a Chevy Trailblazer, used, had keyless remote access Viper Alarm after manufacturer. Had trouble with transmission and alarm....took to Chevy dealer they replaced transmission. Now the remote...
You need to find the black push button called the valet button. That is the overide. Get in the car turn the key to IGN as the alarm is going off and then you have either 5 or 10 seconds to push that button once and then 2-5 seconds later the alarm is shut off. To put the car into valet mode which means no alarm at all you put the key to IGN push that button once then pull key out at which point the blue light should turn solid blue.
Or option two is you open a door and hit the lock, then unlock, then lock button again on the remote and the blue led will be solid which means no crazy alarm.
Mar 08, 2010 | 2004 Chevrolet TrailBlazer
Pantech c150 stuck in headset mode - no headset plugged in
open the headset port on top of phone and push the little square adapter connector part down with your nail, and that will take it out of headset mode..
Jul 21, 2009 | Pantech C150 Cellular Phone
Sony CDX-GT710 subwoofer installation trouble
HI
I have a cdx gt 710 deck i am having a problem with.i had it in my grand prix and took it out to put in my new to me honda.When i did this i turned it on , the deck went to test1 mode.it looks like it is in demo mode.I had this problem when changing the battery.The tech fixed it before by pressing two buttons together at the same time,Of course i forgot witch two buttons.
If you could help it would be great.THANKS
Jun 08, 2008 | Car Audio & Video
Trouble turning on my cell phone
I would take out the battery and keep the power button pressed for 15 seconds. After this power cycle, put the battery back in and try to turn it on.
Aug 29, 2007 | T-Mobile Dash Smartphone
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
