Question about HP Compaq nc6000 Notebook
My laptop gone off in 1/2 an hour even its full charged
    Novelist:
  • 107 Answers
Batteries have a life expectancy. Using HP Battery Check, you can determine if your battery is in good condition or needs to be replaced. You can download HP Battery Check from here - click this link
Download and run the software on your PC. Run a test, just follow the on screen instructions and it should tell you the current health status of your battery and what you need to do.
Hope this help. Goodluck!
Posted on Mar 23, 2011
Acer 4830 battery suddenly dead
Your battery is still alive, the problem is in the laptop, it may have a blown resistor or charging ic. I can bypass these parts tru jumpering if ever these parts are not available in the electronics store. Now, take the laptop in the computer repair shop nearest you for this is a hardware related problem.
Feb 01, 2014 | Acer Aspire Timelinex 4830t6443 Core I3...
Emachines charging
I've gone through exactly what your're going through right now.
I'm sorry to say but your battery is dead, you need to get it replaced. It can be replaced under warranty, if you have it.
To avoid this kind of a problem in future take care that you:
1. Don't let the battery drain out after your PC warns about low battery.
2. Try to maintain it's charge when you are not using it for days. The self discharge of the battery may take it below the critical level even when you're not using it. So keep charging it even when you're not using it.
3. Preferably use your laptop on external power supply (keep it on charging while using it whenever possible), charging it even when the battery is full doesn't hurt.
4. Let it have a charging and discharging cycle at least once in two weeks.
The above steps will help you maintain a good health of your battery and avoid the problem you're in currently.
Aug 31, 2013 | Computers & Internet
Help!!! Is my laptop battery broken?
99% charge is still pretty good so I'm not sure whether the HP health check is accurate. The only way to check is to unplug the mains voltage and see how long the laptop goes until it shuts down. This will help REFORM the battery to a degree and MAY restore your missing 1% of charge capacity. If the battery lasts more than 1.5 hours it's still pretty useable - why spend? Also if you do decide to buy a brand new battery and the old one lasts the best part of an hour you could keep it as a backup. Good luck.
Jun 07, 2013 | Battery Biz Computers & Internet
Why my acer 4741G battery can't charge until 100% and stuck until 86% charge even I have to wait for 3 hours?it's already 1 year since i buy this laptop. Need more assistance, I hope for next, my...
Typical behavior of a faulty battery, cells are not accepting full charge... If its still under warranty, you can get the battery replaced no charge, otherwise you're in to fork out over 100 USD for a new battery pack.
Aug 20, 2011 | Acer Computers & Internet
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
How many hours we should charge the battery fist time Nokia-2700
There are basically 3 types of chemicals currently being used for cell phone and laptop batteries. Ni-cad, Ni-mh and Li-ion. There is a fourth makineg its way in Li-ion polymer. A couple things are consistent for all types of batteries no matter what chemical is inside. You must initially give the battery a 12-14 hour charge on the home charger. (Don't use a cigarette adapter for the first charge. This conditions the battery and don't take it off the charger that first time even if the charging indicator says it's full after 3 hours. Also the manufacturer's also state to run it thru 3 charge cycles. What that mean's is that you fully charge and fully drain 3 times. 1 full charge + 1 full drain = 1 charge cycle. Here's where the way you charge the battery starts to differ.
Ni-cad: Mostly only on older devices, has a "memory" effect, should be drained before a full charge is put on it, should be removed after overnight charge or can be overcharged and burnt out.
Ni-mh: Still used for some devices, has slight memory effect but not enough to have to fully drain before the recharge, should not be consistently left on charger after full charge that can eventually burn out battery and shorten usage time.
Li-ion and Li-ion polymer: Used on a lot of newer devices, has no "memory" effect, should be recharged as often as possible, actually likes to be charged and draining it regularly can cause the usage time to be shortened, can NEVER be overcharged so whenever you're near a charger put it on there. Besides those benefits a li-ion battery is lighter and smaller but the chemical can hold more charge than Ni-cad and Ni-mh.
So the one reply to your question said to error on the side of draining the li-ion batteries. This is incorrect information. You want to charge the battery before it gets below a 20% charge. Also batteries will not go bad from accidentally doing the incorrect charging procedure here and there but normally follow the correct procedure. One last note try to use the home charger more often than the cigarette lighter charger for best long term results. Cigarette lighter chargers do not give a full charge (about 95%) which in the long run can damage any type of battery listed.
Oct 07, 2010 | Nokia N70 Cellular Phone
Panasonic ES2206 elec razor vibrates but doesn't shave
if u had this for over a year and used it every day most likly the batties are gone, but u can try this, use the shaver until all the charge is gone complety wait 10 minutes charge the shaver for a full 24 hour without using it or unpluging it and see what happens some time u need to reset the battery for a full charge
Nov 11, 2009 | Health & Beauty
Will a bad battery keep a laptop from turning on. the laptop will not turn on unless you take out the battery and use the a/c power supply only
if the battery is bad, yes. Also, if the batter charging circuit is bad, yes. The thing to do is get that battery tested in a shop, or, have another battery like it to try. Batteries are expensive and only have a 1 yr warranty. But, most people do not use the batteries because they are on an AC plug.
Oct 26, 2009 | Dell Inspiron 2200 Notebook
My laptop battery is not charging 100percent
Your Battery gone bad. So replace your battery.
If you have active contract call bto your laptop technical support they can help you in replcaing it.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 05, 2009 | Computers & Internet
My Aspire 3680 Laptop will not charge the battery.
Although both could be the culprit, it is far more likely that the battery has gone dead.
Jun 29, 2008 | Acer Aspire 3680 Laptop
HP Compaq nc6000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
