Question about Zebra TLP 2844-Z Thermal Label Printer
The label prints fine but sucks it back in just a little where you cant rip it off
  • 604 Answers
Add a space after your last letter and see if you can get it then
Posted on Mar 23, 2011
Printing too light
Hey,
You need to go to your driver, check on the darkness parameter on the advanced tab option.
Once you are there, you will see that there's a graduation from 0-10 or 0-20, depending on Printer driver you are using.
Try downloading your printer driver from www.nicelabel.cl and then you will have a 5 degree default.
You have to start testing little by little upgrading the degrees.
If that doesn't work, then you have to check the material you are using. Normally you must use wax ribbon to print on paper and resin ribbon to print on polypropilen. The ribbons look the same sometimes. To know about the label, try ripping it. If you can is paper, if you can't is pvc(Polypropilhene)
Jun 10, 2014 | Zebra GK420t thermal transfer and thermal...
After calibration the first print is fine.. 2nd print to label seems to backup into the printer before the next print ..result in text missing info... workaround is ..I need to pull the label out a little...
Sounds like you are printing from Zebra Designer, if so all you need to do is click File/Printer settings/Advanced setup/tick the box marked "Top of Form Backup" OK, and then save your label file.
Nov 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
MY ZEBRA TLP 2824 PRINTS IN THE MIDDLE OF MY LABELS.
Don't shoot it, they're too hard to cook.
Make sure your program is set for the label size you're using. Also, there is a photo eye under the paper path that picks up the labels. It will, in time come out of adjustment. It can be cleaned with a swab and alcohol.
Sep 01, 2009 | Zebra TLP 2824 Printer
Zebra S600 Printing
You have to program the tearoff.
See the manual or use a windows driver to end the value to your printer
Aug 24, 2009 | Office Equipment & Supplies
Eltron TLP 2642 sucks labels back inside
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default.
Aug 04, 2009 | Office Equipment & Supplies
HP Deskjet 6980 will not print Labels using Microsoft Word
You could be printing a font the printer does not know. Make sure it is capable of printing the version you are trying to use.
Jul 11, 2017 | HP Deskjet 6980 InkJet Photo Printer
HP laserJet 2100 prints blank from manual tray
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Oct 31, 2008 | HP LaserJet 2100 Printer
Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Feb 10, 2008 | HP DeskJet F380 All-In-One Printer
Printing blank labels between and after printing tags
your printer needs to be calibrated and set label lenth in the driver in both printer preference and printer defaults
Jan 16, 2008 | Zebra Eltron TLP 2742 Thermal Label...
AS400 Spool files stuck in outq in send mode
I have WiFi Zebra QL420. In my case a simple header label prints fine then the complex label (many fields, barcode, lines & boxes) gets stuck. Labels are in separate spol files. We have many other labels printing fine, just this one ALWAYS gets stuck.
If I send same data from PC to printer it works fine.
I can see with ethernet sniffer that header label data goes but complex label doesn't even leave the iSeries. My sniffer is too crude to tell me what LPR level protocol is saying.
Oct 10, 2007 | Printronix T5000 Thermal Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
103 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
