Question about Garden
I just want a picture that show me how to take the coil off a poulan pro ppb250e 31cc
  • 718 Answers
Go to you tube !!!
Posted on Mar 24, 2011
How to test a poulan pro 31cc ppb 250e gas string trimmer kill switch
The proper way to test it is with an ohm meter by doing a continuity test. If your switch isn't working on the machine, there is the possibility that the wire from it that connects to the coil module is loose or is off. I would check for that first and then do the continuity test if needed. The coil is under the front cover of the machine and will require disassembly to access where the black switch wire spade terminal is.
Oct 21, 2010 | Poulan Garden
Need a gas line diagram for a poulon pro ppb250E
i need a gas line diagram for a yamaha vmax it leaks gas all over
Sep 18, 2010 | Poulan Garden
What is the rotation direction of a Poulan Pro PPB250E 31cc 17-inch Gas Trimmer, replacing the head and need to remove original
hold the head & undo the unit in a clockwise direction because arbor or adapter is left hand thread
should be so,e means of stopping rotation of shaft so can undo head - may be place a small rod in the hole to stop adapter plate rotation -
remember normal thread left y loosey - righty tighty
but with left hand thread opposite applies
left - tigthen , loose - right
cheers
Aug 14, 2010 | Garden
Poulan Pro PPB250E trimmer won't idle
clean and repair carb, make sure the mounting gasket is ok. and does not have a vacuum leak.
May 28, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Where do I get the little tool for adjusting the carburetor settings on a poulan pro multi-attachment weed **** PPB250E
The part number for this carb tool is
530-035560 and it is made by Poulan.
Not sure where you can purchase unless there is a small engine repair shop near you. If they deal in Poulan they may be willing to order one.
Otherwise, try on net for small engine repair.
Dave's Radiator is a good one.
Jun 17, 2009 | Garden
Garden Logo
142 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
