Question about Refrigerators
Hello what temp should i have my fridge/freezer at the freezer unit is working but the top is warm, thanks, Sheryl
  • 3,289 Answers
Sheryl -
Most manufacturer's suggest 0 deg F for the freezer, and 34 deg F for fresh food compartment. You determine the fresh food temperature by filling a 6 to 8 oz glass with cold water and placing a thermometer (capable of reading 32 deg F) in the water. Place the glass & thermometer on a shelf in the fridge. Allow it to assume the temperature on the fridge and hour or so. The glass of water is to minimize rapid increase in temperatures seen when the door opens.
Make your adjustments from there. Allow temperatures to stabilize for up to 24 hours if the fridge is full, much less if empty before making additional changes.
I hope this helps and good luck! Please rate my reply. Thank you.
Posted on Mar 23, 2011
Why are my fridge and freezer to warm?
Sounds to me like your freon is low. That is the gas fridges use to cool things down.
I may be wrong but I would get a repair man to check the freon pressure first.. Low freon is caused by a small leak in one of the lines or in the compressor its self. I had an old fridge and the freon went low just over time.and had to be topped up.
Jan 13, 2015 | GE Refrigerators
Hello, we have a kenmore freezer on top fridge on bottom & it is not cold. last night the ice in the freezer was water/not frozen & the temp in the fridge is 60 degrees. can you help us as to what...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 21, 2011 | Kenmore Refrigerators
GE side by side. Top shelf in fridge warm. bottom drawers frozen. Freezer working fine. Seems to be blowing a lot of cold air out the vents by the floor. Top shelf in fridge is 55 degrees. Diffuser...
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
Dec 29, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Hello, I have a side by side Model # MSD2758GEB Refrigerator. The freezer is working fine but the fridge does not cool well. There isn't ice jam where the air is coming from. I checked the back of the...
You have a defrost problem. You will need to thaw out your unit by turning the fridge off for a day or night before you install the new parts. if you will give us a call, we'll be sure to send the right parts out to you right away so you can repair this unit. We hope this answers your questions and we hope to be able to work wit you further. :>)
Sep 16, 2009 | Maytag MSD2758GEB Side by Side...
Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Mar 09, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
Side by side frigidaire
check the evaporator fan motor, behind the back wall of the freezer. If that is turning check if the damper is opening, top lt of the refrigerator compartment. I hope this helps you.
Jul 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
