Question about HP 1901w Monitor
I know this probably sounds silly, but how do I adjust my monitor once I connect it to the stand? I just got it and I don't want to break anything, but it doesn't seem to want to bend/adjust anywhere that I can see.
    Problem Solver:
  • 5 Answers
That model can only tilt up and down. Just hold the base down and tilt the monitor from the top.
Posted on Mar 24, 2011
Can't get it to stand up right, my screen keeps falling down and won't stay up
look for the adjustment screw at the base go from there
and download teh manual
Sep 14, 2014 | HP 1730 LCD Monitor
The monitor shows the sound is on but I don't hear
On what, your oven or is this a laptop or PC, a laptop adjust the sound settings, on a monitor, you need a HDMI cable to get sound from a monitor. And a PC that has onboard HDMI or a graph card that has HDMI.
Mar 29, 2013 | Computers & Internet
Xbox starts to spin disk then gives up
This may sound like a silly question, but could be an easy fix! Are you laying your console flat, or standing it on it's side? Try the other option to what your already doing and give it a shot. If that should fail, you can try tapping the console above where the drive bay is! Although I don't endorse beating your box to death by any means, this has worked for me when I ran into the same problem, up until I just decided that my wallet getting hit for a new console, was less damage then breaking my hand! haha
Aug 31, 2011 | Microsoft Xbox 360 Console
My 97 isuzu rodeo when push for washer fluid doesnt spray
If the pump is making noise when you press the washer-fluid button then it is probably a hose issue. Open the hood of your car and have someone press the button. If you can see where the fluid is spraying out, then you have found the disconnected hose. It should not have fallen too far away from where it is supposed to be connected, so it should not be too hard to reconnect it.
If your washer fluid pump is not making noise when you press the button, then check the pump. If there are no loose electrical connections, then the pump it probably dead. Replace the pump and you will be fine. If you notice a burned looking wire near the pump, then you should be able to replace the wire and be OK -- but this usually indicates that there is a bigger problem at hand (wires usually don't just burn out for no reason).
I know this one is going to sound silly ... but have you made sure the washer fluid level is full? If your tank is empty, it won't spray. Double check this before you spend any money on anything else -- sometimes the washer-fluid tank will crack and leak, so even if you fill it, it will be empty again by the time you go to use it again (it once took me a month to find out that this was the problem in one of my old cars ... ha ha ha ... I felt really silly)
Most likely it is just a hose. Most auto makers use a friction connection for these hoses since it won't kill anyone if it pops off. If you find that this IS the problem, I recommend using a zip-tie to secure the hose where it is supposed to be so you don't have to deal with the same problem repeatedly.
May 27, 2011 | 1997 Isuzu Rodeo
How do I tilt my KDS 92 MWDB monitor. There are 2 buttons on the base of the stand but they don't seem to do anything. I'm afraid to put too much pressure pushing back for fear of breaking it.
Be gentle, but apply pressure if needed. The buttons may require you to hold both in, then tilt the screen. Some models have switches, button, or other things to manipulate the tilt. Check the bottom and the back to be sure.
May 14, 2011 | KDS Computers & Internet
Monitor stand screws
More likely to be metric M4 screws, 1/2" will more likely to be long enough.
Feb 23, 2010 | Acer AL2423W LCD Monitor
After pc gets turned on it goes into sleep mode with no response.. need troubleshooting help.
Hello ahmid7 …
There are three potential areas for your solution (listed in descending order of probability).
1. Power Options
Are you familiar with Windows' "Power Options" control panel module? If in fact your system is going into sleep/stand-by/hibernate mode, this will be the most probable culprit, and you won't need to proceed to steps 2,3. With it you can tweak all things related to power saving (e.g., sleep, stand-by, hibernate, timed automatic MONITOR and/or hard-drive shut off, etc.). Just make your desired (re)adjustments there.
[Control Panel > Power Options]
... OR ...
Start > Run > type "powercfg.cpl" (without quotes), then hit Enter.
Once it launches, you'll probably find most everything self-explanatory. If not:
  • Search for "Power Options" in your Windows "Help and Support". Then review "…Common Tasks…" and/or "…Overview…" related items.
  • Post here again and I'll be glad to walk you thru it.
2. Monitor's OSD (On Screen Display / Setup)
If step 1 is unsuccessful, it may only be the monitor (CRT/screen/display) itself that is turning off. Somewhere on the monitor there will be an OSD (On Screen Display / Setup) button/switch of some type. There you may be able to make the needed adjustment. If necessary, refer to the monitor's documentation (i.e., User's Manual, etc.) for further details.
3. System BIOS
If steps 1+2 are unsuccessful, it may be your computer system's BIOS accommodates auto/timed shutoff of your monitor, hard-drive(s), motherboard. If necessary, refer to your computer system/BIOS documentation (i.e., User's Manual, etc.) for further details on how to adjust.
IMPORTANT NOTE:
If none of the above provides solution, please report this, because it may be that your system is NOT in fact going into what you perceive as a sleep type mode, but rather is experiencing an emergency shutdown. In this case there are a couple of most likely causes. However, there's no need to cross that bridge unless it actually exists.
Good luck, and thanks in advance for posting back ...
  • to provide clarification or feedback.
  • if you have any further questions.
  • to let me know how things worked out.
"Today's the best day of my life...and NOW you're part of it!" … Craig
Sep 19, 2009 | X2Gen MV20TP Monitor
Hi, I hope you can help. I have a Sony Trinitron monitor. It suddenly went a bit out of focus. I am trying to find a restore function, with no success. I wonder if you have any suggestions.
you have to open your monitor back. find a big part called flyback. there is two nossel in it. adjust forcus nobe litte bit for clear picture. this will definetly slove your problem.
Jul 19, 2009 | Sony CPD G420 19" CRT Monitor
Prints blank page my lexmarkx5150 all in one
Okay, I know this may sound silly but make sure the document you are trying to print is not using a White Font. Don't laugh, I've actually see this once before. Next, try a stand alone printer test Disconnect the printer from the PC and using the printers panel go to Maintenance Menu and either print out a test page or a demo document. If that works, then re-connect your printer to the PC and using the printer's driver, print a test page. Last step, make sure that all of the printer setup are the same, especially the Page Set-up from the application. Don
Jun 12, 2009 | Lexmark X5150 All-In-One InkJet Printer
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
HP 1901w Monitor Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
