Question about HP LaserJet 2840 All-In-One Printer
Printing envolpes and now I have jam in print paper path how do I find the the problem
Link below to HP documentation on clearing paper jams. Copy and paste into your browser.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00364368&jumpid=reg_R1002_USEN
Posted on Mar 23, 2011
  • HP Master
  • 1,915 Answers
If the jam is not evident in the feeder, then you need to open the printer, remove the imaging drum and look straight down to the bottom. This area is called the registration assembly and it is the most likely spot for a jam to occur. If you see any paper there, carefully remove it. Turn the printer off first before reaching in there.
Can HP color laser jet CP1215 print envolpes
You should be able to put single envelopes through the printer. Just be sure to select paper type as envelope as this will slow down the printing process and ensure that the toner bonds to the paper.
Jun 28, 2016 | HP Office Equipment & Supplies
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Hp laserjet 4200 will print a 50 page paper path test, print an extra page and then jam.
The paper feed solenoid is sticking. There is a foam material that deteriates over time and becomes sticky. I remove what's left and put masking tape in its place.
Oct 03, 2012 | HP LaserJet 4200 Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
When trying to print from the cassette get paper jam error but no paper is jammed. It doesn't even pick up the paper in the cassette. The error will not clear. Any suggestions as to what to do? It will...
The 6A00 is a Canon generic code for paper path jam. Somewhere in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if it is jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs Incidentally, the 6A00 error pertains to all Canon printers made in the last several years; it is not just used in one model. And it is always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow. Move back and forth several times (with the power off)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 08, 2010 | Canon PIXMA MP620 All-In-One InkJet...
My printer pulls the papper half way to print and then it sound if it was printing but the papper doesn't move i already restarted it unistall the program n reinstall and it still does the same thing
check paper path with test print
right click printer icon go to properties click test print
can you see and remove the jam in paper path Check rollers for slick coating on them they are soft rubber and can get glazed so to speak
remove all parts that you can including paper drawer recheck the paper slot adjustments
sounds simple fix just recheck the paper path for jam or glazed rollers
1 Question ??no error message ?
Jun 11, 2010 | Lexmark Office Equipment & Supplies
Printer mispick
Hi ,
The print engine has failed to pick up a piece of media.There is a paper jam in the printer's paper path. Reload the paper in the paper input tray; verify that there are no jams in the paper path, and press MENU/ENTER to continue the job. If the error persists, replace the printer pickup roller. Check paper path, including rear output door for jams, fuser area, and under the print (toner) cartridge.
Feb 10, 2010 | HP LaserJet 3330 All-In-One Printer
New out of the box 13:20 error paper jam there has never been any paper in machine we're just setting up. open and close front, then theres a fuser jam lift and close top, front door again.We have paper in...
PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
Jun 24, 2009 | HP LaserJet 3600n Printer
Envolpe feed problem
I would first off try cleaning the feed roll in that tray well. That really sounds like slipping.
Go through all your programs and make sure that the driver machine and program you are running has the envelope settings the same.
Be sure they all match. Example. Make sure all the programs you are running through, have the settings for # 10 envelope, consistancy is needed for running envelopes. They are problematic.
May 01, 2008 | Xerox Phaser 8500/DN Printer
HP LaserJet 2840 All-In-One Printer Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
