Question about Toshiba Satellite A40-S161 Notebook
Ha a Toshiba Satellite a100 I can not turn off the touch pad (as I only want to use the mouse). Both touch pad and mouse are working. the laptop had to be reformatted recently and its since then All drivers have been loaded so I am told. I aThings I have tried n not find anything about a touch pad to change1. Reloaded the driver 2 Tried to find the driver in device manager but cant It doesn't seem to be with mouse and other pointing devices 3. Went to systems then mouse and couldnt find anything about touch pad
    Novelist:
  • 107 Answers
If your computer have a, Synaptics Touchpad you can try these steps:
1. Access the properties of the Synaptics Pointing Device by right-clicking on the system tray icon at the bottom right-hand corner of the screen. If you do not see the icon, open your Control Panel and select the "Performance and Maintenance" option. Click "System", then "Hardware", then "Device Manager" to view the devices on your computer. Open the "Mice and Other Pointing Devices" selection.
2. Click on the "Device Settings" tab of the "Mouse Properties" window. The "Device Settings" tab is at the top of the window and located farthest to the right
3. Highlight the Synaptics Touchpad from the list of available pointing devices. Click the "Disable" button underneath the list. Click "OK" on the pop-up menu to confirm your selection. Click "OK" on the Mouse Properties window to close the window. Your Synaptics Touchpad will now be disabled.
Make sure to connect a USB mouse to your laptop before disabling the touchpad so that you will still have control of your pointer.
Hope this help. Goodluck!
Posted on Mar 23, 2011
TOUCH PAD ISN'T WORKING, CURSOR WON'T MOVE on my Samsung chrome
Make sure the keypad is not locked on accident might be a function key and an Fkey. See if an external mouse works fine.
Jul 10, 2014 | Toshiba Satellite A100-S8111TD Notebook
The touchpad is so sensitive I can't control it
You've got it, your touching the touch pad, annoying isn't it.
You can try a couple of things,
1) Go to Start - Control panel - Mouse/Touch panel - and see if you can reduce the sensitivity or,
2) Disable your touch pad (Same route) and use an ordinary mouse instead. That's what the wife does.
Jul 09, 2010 | Toshiba Satellite A100-S8111TD Notebook
The mouse on my laptop doesn't work, but the external mouse plugged into the usb does. Any suggestions?
Touch Pad setup with the usb mouse installed for easy navagtion
check the device manager for mouse mouse and other devices
look for nthe touch pad label
look see if it is running ok and enabled.
Make sure it is.
Go to control panel open the mouse icon
touch pad mouse properties
Here is where the controles for external and internal mouse settings will be found.
The rest is up to you
Jun 26, 2010 | Toshiba Satellite A100-S8111TD Notebook
Replaced my toshiba laptop key board and now my touch pad cursor does not work, but a plug in mouse will. Any ideas on what I can do to get the touchpad mouse working again. Thanks. Shawn
when plugging the touch pad flat ribbon cable back in .it might have popped out.or you might have plugged it in and missed the proper slot...try that
May 25, 2010 | Toshiba Satellite A100-S8111TD Notebook
Touch Pad on my laptop is not working
Follow the guide below to tear the laptop down, you are extremely fortunate that the device is even working. Electronic sircuits and water have never been a good match, and your keyboard and touchpad are essentially just large electronic circuits. There is probably some water still somewhere under the keyboard and it is probably in contact with the tochpad cable or socket. When you have the keyboard off, use a hair dryer on warm and completely dry out all components and make sure all the small flat cables are tight in their sockets.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Dec 13, 2009 | Toshiba Satellite A100-S8111TD Notebook
Mouse wont move the cusur
Connect another mouse to the computer and see if that is able to move the cursor. This will tell you if it's the mouse or trackpad that is having trouble, or if it's the computer/software having the trouble.
Nov 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
Touchpad on toshiba equium A200-1VO laptop not working
you have lost your driver for the cursor .
go to :
  • www.toshiba.com/taecdpd/support/drivers.shtml
  • this should have all the drivers required for your PC .
    give it a try and let me know how you go
    Sep 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
    Toshiba touch pad not working to tap of finger
    First got to Start/Settings/Control Panel/Mouse(or there may be a separate Touch Pad setup) and check were options for touchpad Settings Options are tabbed or listed.
    All touchpads allow on/off settings for Tap or NoTap. Also, check Sensitivity Settings. If very low, then Tap would have to be very hard to be recognized.
    Next, reboot your computer.
    Feb 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
    Touch pad will not work
    Hold down the FN button and up on the top of the keyboard there will be a button with a picture of a mouse. As your holding down your FN button hit the other button and see if it enables your mouse. Something should come up on the screen showing you that its enabling or disabling the mouse.
    Feb 11, 2009 | Toshiba Satellite A100-S8111TD Notebook
    When typing on toshiba the curser skip and actually moves
    It might be that your palm is brushing across the intel touch pad (mouse pad) as you're typing?.. try holding down the function key (Fn) (on the lower left corner of the keyboard) while pressing F9 (this activates the "Toshiba Flash Cards Menu" and is a keyboard shortcut to toggle off/on the touch/mouse pad. You can turn it back on this way too. I almost always use a conventional USB mouse with my laptop for this reason and because it's faster than fiddling around with the pad, IMHO).
    Dec 26, 2008 | Toshiba Satellite A100-S8111TD Notebook
    Toshiba Satellite A40-S161 Notebook Logo
    335 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
