Question about Kershaw Knives Kershaw Ken Onion "Blackout" Folding Utility Knife
How do I take out the lanyard hole fixture to completely disassemble my Kershaw 1550st?
Seadoo
I'm guessing you are talking about a PWC Seadoo. :-)
But you need to check the lanyard switch. There are two wires to the switch, the switch only connects the two when the lanyard is in place. So if you can locate the connector under the hood, just jump the wires together to check the switch wiring.
Note: You can not operated the PWC on the water with the wires jumped, it's against the law.
May 25, 2014 | Video Game Consoles & Games
Missing part
It's pipe thread, measure hole size and try a good plumbing supply depot. Attach a lanyard to the plug to avoid losing it next time, or re-install it after drawing.
Apr 21, 2014 | Annovi Reverberi RMV2.5G27D Pressure...
Bucket lanyard, where can I replace mine.
I think you have to give your handbag to handbag repair shop for replacing lanyard. You can replace it by designer lanyard which gives unique look to your handbag.
http://www.cheapsnapbacksun.com/
May 03, 2013 | Alviero Martini 1a Classe 1a Prima Classe...
NV250 How do I attach a lanyard
Cell phones do not normally have attachments for fixing a lanyard to the phone.
If you want to attach a lanyard you maybe able to get a stick on attachment to attach to your phone or a protective case for the cell phone which has a mounting for a lanyard.
Mar 12, 2012 | LG Cell Phones
I want to replace an old single handle builders no-name shower, about 15 years old with a gromhix 34436 unit. My shower is tile. What steps should be expected? Is this practical?
Usually a shower stall will boarder a wall where you can access the fixture by cutting a hole in a boaring wall to get at it. If it boarders a closet or someplace thats not conspicuos, there may already be an access hole. Once you have access to the old fixture, you can remove it and, as long as the new fixture is the same size or larger, it shouldn't be that much of a problem. You may have to make the hole in the tile larger but, you should be able to do that with a 90 deg. grinder. Usually most, if not all, shower valve(single) have pretty much the same configuration. If your pies look to be in good condition, you should be able to work with piecing in the new fixture. If you cannot access the fixture from the back sie, well, thats a different story and, alo of work in redoing tile you probably won't be able to match and, a little bit of drywall work but, if you only cut the hole a sbig a you need it,you use some sort of fired decorative tile to cover the repairs spot. It's up to you.
Jun 06, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
Where can I find a schematic and detail strip instructions in order to completely disassemble my Kershaw Leek for cleaning?
there are several videos on you tube and torsion bar kershaw will do they are basically all the same. very simple take your time dont force anything watch videos several times if you have to
Mar 25, 2010 | Kershaw Knives Kershaw - Leek Series...
I cant keep the screws tight in the pocket clip and can not find a star driver to keep them tight
Sears should have the small torx driver you need, put a dab of Locktite 262 thread locker on the screws when you put them in, they won't be going anywhere.
Jan 24, 2010 | Kershaw Knives Kershaw - Leek Series...
Strap
hi clarkent,
  Should you want to attach a hand strap or lanyard to the phone, simply remove the phone’s back cover and lift up the right side of the ‘power’ button’s rubber to reveal the strap hole.
good luck
Jul 03, 2008 | Sony Ericsson K800i Cellular Phone
Kershaw Knives Kershaw Ken Onion "Blackout" Folding Utility Knife Logo
88 people viewed this question
Top Kershaw Knives Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Kershaw Knives Sport and Outdoor - Other Expert? Answer questions, earn points and help others
