So i lose my Literati charger right after my birthday! I cant find it anywhere and i found my old t mobile charger and it fits perfectly. But i cant tell if its chargeing and it wont turn on! Please help me
  • 3,289 Answers
Stop!
There are no voltage and amperage "standards" for low voltage connectors found on devices made to run from an external "wall wart" or transformer type charger or adapter. Just because a connector "fits" does not mean the power is 1) the correct voltage 2) correct polarity 3) correct type (AC or DC) or 4) can supply the amount of power needed to operate the device.
You may have done irreversible damage to your device by literally "grabbing any old charger that fits" to power it. Obtain the correct charger - or if unable to find one; determine the characteristics needed by the device - those variables are listed in 1 through 4 above.
You may find adjustable power sources that allow 1) changing of tips to fit the device, 2) a selector to choose from a range of voltages, 3) a switch to select AC or DC output and 4) the ability to plug in the tip backwards so that the polarity reverses. The last thing needed, is to know how much current in amps or power in watts is needed by the device. The charger / adapter should be chosen on its ability to supply this power continuously - never choose a charger / adapter that provides less than any of the electrical requirements; otherwise damage to the charger or device may occur - and if left unattended, could overheat and cause a fire.
I hope this helps and good luck! Please rate my reply. Thank you.
Posted on Mar 23, 2011
  • kathykinzer
    kathykinzer Aug 14, 2012
    on the back of the unit, bottom, very small print..5 volt 1.5 amp, rather large for 5 volt, but needed to charg a 1 amp battery. center is positive,
  • Steve Aug 15, 2012
    A 5 VDC 1.5A supply will run the device without a problem - as spec'd on the label. If you wish only to charge the device, you could probably do so with a charger of the same voltage, polarity, etc. - but with a lower current (amps) value. This reduced output charger will charge the battery, but at a slower rate that the original. You should not use this reduced output charger to operate the device, but only to charge it.
Actually it doesn't turn on just because you plug in the charger. you have to turn on your literati then plug in the charger and if it is charging it will tell you.
Posted on Mar 29, 2011
What retail store can I find a battery charger for a terminated scooter
hi the new charger plugs & sockets will not fit that if u cant get the old type charger have a look on E/BAY they have chargers as low as $20-00.but u will have to change youre plug and socket u can buy tem on e/bay c photo .good luck hi again I just thought of another way if u buy a XLR CHASSIS SOCKET FEMALE 3 PIN COST ON E/BAY aprox $6-00 U CAN USE THE NEW CHARGERS ...cheers
Aug 29, 2015 | Health & Beauty
My Literati will not update or download books.
Hi, Pam. I feel your pain! I had a Literati for about two years, and when it died a couple of months ago I pounced on a new one from a reseller. Alas, the Literati website no longer exists, so the new reader tries and tries to retrieve that critical update but always fails. Too bad, because the reader as shipped is very buggy (doesn't have all the font sizes/options, can't log in to Kobo [I can't select the login button once I've put in my password], can't even recognize the SD card). Calls to Sharper Image booted me to Kobo; Kobo's very nice e-mail said that they can't help with hardware problems and gave me the MerchSource website, along with a couple of phone numbers. The MerchSource website gives only a phone number--for Kobo. So I called.
I just got off the phone with a very friendly young man who informed me that, sadly, they do not have that software update lurking anywhere. He apparently scored a $10 Literati somewhere that he's experimented with so he could understand his customer calls, and the only thing he's found is this discussion site. He says he's had good luck using Adobe Digital Editions (discussed on that site) to get things onto the reader. I haven't tried it yet (still at work), but there are detailed instructions given.
I hope this helps!
Mar 05, 2013 | Sharper Image Literati Reader 16375680042...
Cant get it to charge correctly how do i fix it ?
The charger not only has to fit identically but must have identical electrical characteristics.
Jun 21, 2017 | SanDisk Sansa Audio Players & Recorders
Can.t get literati to sync with kobe ebooks.
Found this written by someone on another website - worked great for me - not a problem since - have downloaded books via Kobo website straight from the device, everything works perfectly. Thank goodness this person posted.
Go to advanced and reset the system to the mfg settings & it will power down. Turn back on, don't set the date/time & instead reset the system again a second time. At this point it may take awhile to power down and come back on but once you go thru this process, your Literati will update w/ the latest software and work. I followed these instructions and works great now no problems at all.
Jan 09, 2011 | Sharper Image Literati Reader 16375680042...
Unable to join network
Dec 27, 2010 | Sharper Image Literati Reader 16375680042...
I can not get my literati to join with my network
It needs the latest firmware 1.9 or 2.0 for the wireless to work correctly. The solution is to get the usb to work first. Plug and unplug the usb, try powering on with usb plugged in until you get the pc to recognize the drive in the literati. Once you get to this point you have it made. Browse the drive and find the "Desktop Installers" folder run the windows install - the pc will then go out to the internet and get the desktop software version that can update the literati. Once the desktop software finishes installing it will tell you that the literati must be updated. Let it do it. Power off literati or reset it. When it comes up again the desktop software will say there is another update. This one is a big one. After it finishes Power off or reset literati again and it will load the newest firmware and the device works much better afterward. Also, you might want to keep it plugged in to power while you do this - Don't want it to lose power during firmware update.
Vivitar ViviCam 8600s----I need a charger or docking station for this camera
well I happen to have one here in my posesion and this may help the model # is:jta0302f
Mar 21, 2008 | Vivitar ViviCam 8600s Digital Camera
Computers & Internet Logo
504 people viewed this question
Alun Cox
David Payne
David Payne
