Question about Frigidaire Dryers
My frigidaire dryer keeps leaving these rust color stain on my clothes and keeps putting holes in them. some times stuff gets stuck in this gap between the dryer drum and where the door shuts how can I fix this. Is there a part that needs to be replaced? Also where do you find the model number of the dryer. I can't find it anywhere on the machine. Thanks!
  • Frigidaire Master
  • 3,740 Answers
The model number is on the inside of the door:
http://www.frigidaire.com/faq/laundry/dryers/where-can-i-find-my-dryer-s-model-and-serial-number
The symptom you describe is often caused by worn drum seals, drum guides and a bearing support.
See this youtube playlist: (First 2 videos show the installation of the dryer maintenance kit) Note there are 2 different part numbers one for full size and one for compact dryers.
http://www.youtube.com/view_play_list?p=CED5E7B2716D6091
Once you have the dryer apart you can sand the rusty areas clean and repaint the applicable damaged / rusted area with the same color "Appliance paint."
There are worn / failed parts in your dryer at the moment that must be replaced even if you did do the touch up painting or the symptom would soon repeat.
Your model number will be required if you need further assistance or to order parts.
Thanks for choosing FixYa,
Kelly
Posted on Mar 23, 2011
  • 1,998 Answers
Replace the drum guides that hold the drum in place these are small plasic guides and they do tend to go with time and use of the dryer this is also what is causeing those rust colored marks on your clothing as well if you are able to message me back your make and model number i can provide you a schematic showing where these guides are located and how to go about ordering new ones for you unit also if you have any further questions message me those back as well and please remember when our chat has concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
  • Kellymsmith0 Aug 18, 2011
    Kennmore stackable model 417.90872991
    Serial xe11601625
    Great machine had serviced last years but warranty is over and now dryer is tearing tiny holes in clothes and rust marks
My dryer is leaving rust stains on my clothes
you needto replace your dry drum .
Sep 30, 2015 | GE Dryers
My dryer is eating my straps on my clothing
My guess, since I can't see it, is that the gasket between the drum and the back of the dryer (which keeps stuff from passing between them and into the innards of the dryer) is worn and creating a gap that your clothes are slipping into.
Nov 15, 2012 | Dryers
Drum squeaks and clothing gets stuck in drum and and stains clothing a rust color
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 08, 2010 | Kenmore Dryers
My dryer is ten years old. A few months ago, some of the clothes would come out with rust stains on them. Some of the clothes would get caught in the seams which would cause staining, tearing and...
I would suggest replacing the front drum bearing. Sounds like the gap is now excessive, obviously allowing clothes to get caught up in there. Drum must be removed from the dryer to do this.
Good luck, hope this helps.
Aug 19, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Fins inside drumare loose
Open the top ... held down with spring clips ... remove the front panel ... probably 2 to 4 screws ... be careful of the wires ... unplug the machine of course. Remove the drum ... but first observe the belt arrangement so you can reinstall. Tighten the 'fins'. Reverse the procedure.
You can use a pry or large screw driver to pop the top. Be careful of the finish.
Mar 21, 2010 | Dryers
My Frigidaire Washer Leaves Stains all over our clothes
Since this happened from day 1, your water may be the problem. Do you have well water? If so, get a softener system. This will get rid of the iron, which is responsible for rust stains. I really doubt that a new machine would cause rust or grease.
Why didn't you do something five years ago when you first noticed this? It will be much more difficult to get a resolution from the manufacturer after5 years.
Jul 31, 2009 | Frigidaire GLTF2940ES Front Load Washer
Clothing coming out stained with rust colored marks-purchased dryer in 2001
The felt needs to be replaced around the drum. When it wears out, this will cause these marks. The felt is the seal that allows the drum to rotate around the door.
Apr 16, 2009 | Dryers
Frigidaire front load dryer. Been getting
The front tub support needs to be replaced. It is a felt seal the tub rides on and is getting worn, and the sheets are getting between the drum and seal. no the dryer does not need to be replaced.
Mar 08, 2009 | Frigidaire FEQ332E Electric Dryer
Dryer is leaving brown streaks on cotton clothes
The 417 dryers have two seals on the front panel, the top seal has drum glides which wear down over time. Because the drum rests on those glides, when it wears down it leaves a gap between the drum and the seal, clothes will drag in that gap and come out with rust and/or seal adhesive stains. Try replacing the top and lower seals, this works most of the time...sometimes though, if left unattended long enough, the lack of support from the front glides causes too much strain on the rear drum bearing, and even after replacing the seals clothes may still catch, although the brown spotting will stop for awhile. You can feel the gap if you run your hand along the inside of the drum at the seal point.
Dec 29, 2007 | Kenmore 73952 Gas Dryer
Frigidaire crown series dryer
The back of the drum has a hub (a flat steel piece with a shaft and ball) which allows the drum to turn. That ball rides in a plastic "cradle". Unfortunately on the crown series...if the ball and cradle are not greased regularly, the plastic wears. This allows the drum to "sag". The front end of the drum is lower than the back. You can confirm this by running your finger around the front of the drum. You'll notice that the top of the drum is almost flush with the body of the dryer and the bottom of the drum is 3/4 of an inch lower that the the body. This allows clothes to slip into the gap at the bottom and then they are spen to the top pof the drum were the lodge between the body and the top of the drum. The turning drum burns the clothing. Replace the plastic piece that the hub rides in.
Dec 28, 2007 | Washing Machines
Dryers Logo
188 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
