Our washing machine Model General eletric C86 in position No 7 does not drain water. Does this type of machine is a filter that can be cleaned?
futureloginn
  • 734 Answers
SOURCE: miele washing machine wont drain
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
barkencoa
  • 3463 Answers
SOURCE: Hi i have an indesit
Your model of washer dryer is fittted with a self cleaning pump, and may not have a filter fitted.
To check if it has, remove lower plinth at bottom of m/c, and if there is a plastic panel there ,remove that as well.
If there is a filter fitted, you will see it at the bottom right front, it has a round cover, unscrew anti clockwise, remove and clean filter.
Pleas leave a fixya rating if you consider my solution appropiate to your query.
Thankyou.
Posted on Jan 30, 2009
  • 3741 Answers
SOURCE: washing machine will not drain. water wont drain
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Aug 20, 2009
barkencoa
  • 3463 Answers
SOURCE: the water wont drain from my machine from the wash
What you need to do is check the pump is getting a feed to it
Select a spin cycle, and with a test meter, test for voltage across the pump terminals, if you are getting a feed, and the pump is working ok, then you obviously have a blockage beyond the pump.
If no voltage then could be a broken wire, or a faulty programmer/board.
ONLY CHECK FOR VOLTAGE IF YOU ARE COMPETENT TO DO SO, as it takes no prisoners.
Hope this helps.
Posted on Dec 07, 2009
SOURCE: washing machine wont drain have cleaned filter
the waters not coming out the mechine
Posted on Dec 19, 2009
Washing machine won't drain
you did not provide such important details as brand and model... telepathy is overrated and works only on the movies, advice given is then only very general, i do not know your model, cant say whre bits are located then:
1. switch off the machine
2. disconnect from power point
3, have flat screwdriver (maybe not needed in your case) and long nose pliers, good torch will be handy as well
4. have plenty rags ready...
5. somewhere on the bottom of the machine you will find little door or plate, screwed in or clip in, open it
6. there should be screw in filter cover (in older models often you need flat bed screwdriver to undo screw and remove the cover) it is usually 1" to 2" (25mm to 50mm) diameter
7. remove cover, expect flood...
8. there should be cage inside - you need long nose players to remove it and empty all coins, buttons, lint, dog and your hair and everything else from the cage
9. use torch and inspect further the filter unit - you should see clearly the rotor of the pump, check with your fingers if you can freely rotate it and if there is no noise, clinking or whatever else, clean all debris, wounded hair, lint, small coins if there
10. re-install filter cage
11. close the filter so it will seal but not overtighten it!
12, start shortest washing cycle and check if water is evacuated from machine
13, if water evacuates, you fixed it! put cover back and every year or so try to clean it...
14 if water do not drain - try to check all piping to the pump and from the pump, easiest way is to lay wash machine on it's side and remove hoses to and from the pump, they are usually held by circle clips and players are useful again, check for debris in them
15, re-install hoses and turn machine to the correct position
16 repeat step 7 to 12
if water does not empty after that, most probably waste pump (you just cleaned all of that) is gone, it is easy to replace but it exceed the scope of this little instruction.
Dec 29, 2014 | Washing Machines
Sir, i am working washing unit company,i am having one problem in w455h 6kg machine,in my unit all washing machines are connected in plc and pneumatic valves,then the problem is water in automatically not...
This might not help you- if not, I'm sorry.
Does each machine have its own water outlet filter? If so I would suggest as a first step that you clean the drain motor lint tray/filter.
Here are my complete, general pre-typed guidance notes for checking the filter ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Hope the filter is the problem and good luck!
John C
Mar 16, 2011 | Electrolux Washing Machines
Once the washing machine needs to rinse the water does not pump out
You do not say the make and model of your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Mar 16, 2011 | Washing Machines
Unable to drain the cycle water and therefore unable to retrieve washing stuck in the machine.
Sorry you do not say the make and model of your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
John C
Mar 14, 2011 | Washing Machines
GENERAL ELECTRIC WSSH300G FRONT LOAD WASHER PUMP KEEPS RUNNING AFTER DRAINING WATER PRYER TO FINAL SPIN. WASHER WON'T SPIN.
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
John C
Mar 10, 2011 | General Electric WSSH300G Front Load...
Error 5e will not empty model number wf-b1456gw Samsung Washing Machine
Samsung '5e' means 'water drain error'.
John C
Mar 10, 2011 | Samsung Washing Machines
Machine is full of water, wont spin but door still opens and water comes out
You do not say what the make and model of your particular machine is BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
John C
Mar 10, 2011 | General Washing Machines
Water will not pump out of washer after washing
You do not say what the make and model is of your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
John C
Mar 07, 2011 | Washing Machines
Washer will not drain in the normal wash cycle. Did drain in the casual wash cycle.
It is possible that there is less water to drain on 'casual' wash (?)
John C
Mar 07, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
