Question about Brother Office Equipment & Supplies
I can't clear a print job. I have turned it off overnight, but it continues to print (from the beginning I think). I have tried "stop/exit" button which stops printing, but does not clear the job.
    President:
  • 1,623 Answers
Open printer properties and delete or cancel all pending print jobs
Posted on Mar 23, 2011
Printer job will not delete
Try turn the printer off and then back on.
This will clear the last printing operation.
Jan 01, 2014 | Office Equipment & Supplies
Hello, I am using the Magicard Tango 2e. I
Hi Mahom -
It sounds like your printing software has sent the print-job to the Windows print-queue as a single job. Because it didn't complete originally, and then you reset the printer (power-off), it has now lost track of where it was and will only start at the beginning of the job again. Best thing to do is unplug the printer again; cancel any pending jobs in the Windows print queue for the Tango printer; then re-print job EXCEPT for the cards already printed.
Nov 13, 2017 | Magicard Tango 2 Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
I have an old deskjet 1220c. After trying to cancel a large printing project the printer now spits out page after page of one line "gibberish". I've tried turning it off overnight; unplugging it; and...
You have to empty the print que in your computer, You need to open print jobs and delete the job. otherwise you can turn the printer on and off several times while connected to your computer and it will eventually clear.
Sep 01, 2009 | Office Equipment & Supplies
When trying to print it says
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults.Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Aug 30, 2009 | HP LaserJet 3015 All-In-One Printer
Prints garbage
You have a software problem there. You can try and clear the print job in the computer but more than likely its already in the printer memory and is going to print until its finished. I think you're going to have to let it run until its finished then go back and make sure your computer malfunction is fixed before you try it again. I know its frustrating...but it will eventually stop. You might want to re feed the used paper unitl it does. I'd say turn it off and on...but I don't think that will clear the print job..and you've probably already tried that anyway.
Jul 10, 2009 | Lexmark E260dn Laser Printer
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
Change papersize from LTR to LGL
Turn the printer off for about 10 - 15min ( or even longer ) by removing the power cord.
I had left it unplugged overnight as it was late and had given up on fixing this annoying fault. Once plugged back in it was working fine.
Nov 14, 2007 | Canon imageCLASS MF5770 All-In-One Laser...
Canon ImageRunner 400S - Clear RIP job
I think I can help but its been a long time . you need the clear the print jobs at the PC first then the print serveron the copier. turn the copier off and on, as it starts to warm up press the print button, now when it ask if you want to start setup press yes...scrool around till you see clear print server and say yes ....now reboot.
good luck
REP
Oct 24, 2007 | Canon imageRUNNER 400S Copier
Have canon mf5700 says check paper size and only prints one page of several page job
If your alarm light is flashing and your printer will not print, press the "copy" button to get the device into the copy mode, once the copy button light is on, press the "Status Monitor" button. The LED panel will then show two lines of words: Line 1 "COPY STATUS" and Line 2 "SELECT JOB TO CANCEL"; then hit the Set button and the screen will show you what print job which has jammed the printer and you then press the - (Minus) button to clear the job. Open and close the front panel and the printer should reset and the warning light go off.
I had trouble locating the problem because my machine tends to stay on the Fax mode and when I pushed the Status Monitor button I would only get information about fax jobs.
Hope you have already figured out the problem. I thought I had better tell someone so I will remember the next time I try to print a job which requires a different size paper than what I have in my printer.
Blessings!
tdocdaws
Oct 16, 2007 | Canon imageCLASS MF5730 All-In-One Laser...
136 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
