Question about Refrigerators
Keeps tripping the safety switch - Refrigerators
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
If you had a momentary power loss this symptom will present itself. Try unplugging the unit for 30 minutes and let the coolant system and compressor stabilize. Then see if it starts. If it does start great. If it does NOT start I need a make and model number to better help you troubleshoot. With that information I can provide how to steps and parts information applicable to your refrigerator.
Thanks for choosing FixYa,
Kelly
Posted on Mar 23, 2011
  • Kelly
    Kelly Apr 12, 2011
    My initial reaponse:
    Kelly
    You never bothered providing us with your make and model number yet you rate the post poorly. I could provided you with service manuals and walked you step by step through the entire troubleshooting process. I would have told you where to get replacement parts on line but you did not afford us that opportunity. It makes me wonder why I try to help people for free but, I chalk this up to finding a make and model number was too just too difficult for this particular problem and it will not deter me from helping others. One of FixYas' best took one on the chin for the team:
    http://blog.fixya.com/index.php/2010/05/...
    Kelly
Why does my dryer switch keep turning off
Five reasons why your safety switch keeps tripping The electricians point...
Try the link below and find the reasons and solutions to your problem.
All the best.
Sep 17, 2016 | Dryers
My Bonaire evap cooler keeps tripping the fuse when I turn it on
there is an electrical short in the unit that is causing the fuse / breaker to trip
could be insulation, moisture in a junction connection or failing motor
Call in an accredited electrician to find / fix the fault
Mar 12, 2016 | Dryers
Dryer turns on and spins but no heat
this is most likely a safety switch on heat element has tripped/went bad , this tiny device keeps heater from causing a fire if heater gets to hot , common cause of this tripping is a blocked vent pipe
Oct 30, 2015 | Washing Machines
Fridge/freezer keeps tripping
Try to plug into different circuit, if it trips that breaker on the board then the appliance is probably at fault.
I must assume that you have not acquired something plugged into the same circuit as the fridge.
Sep 26, 2017 | Beko Refrigerators
Trips safety switch
Might be best to call the manufacturer or a licensed repaire to avoid voiding your warranty?
Jan 09, 2014 | Washing Machines
I have a power strip that keeps tripping its safety switch even though only one electric oven is plugged into it. What do I need to do?
did you try to plug directly in to a plug ?
maby your strip is defective or has a 10 amp overload protector this will trip with heating devices of your nature.
Oct 20, 2013 | Rowenta DG-980 Iron
Rool out switch keeping tripping
assume you mean roll-out switch on a furnace....it is a temperature sensitive safety control intended to limit the temperature in the vestabule or burner area. if it keeps tripping, it's because something is causing the temp to get too high. a dirty filter would be first suspect. it could also be an inoperative blower, a dirty evaporator, or a blocked flue or vent pipe. check all these things out and you will likely find your problem..
Jan 27, 2013 | Heating & Cooling
My adp8540 has stopped working because my sister opened midcycle. Now it trips the circuit safety switch and if it does do anything else it blinks 6 times. Can it be fixed or do I jut need a new one?
Please remove off the main power supply and keep aside while pressing off the panel control. If the trip works, check if the motor is struck , release with manual action. Also check the motor, remove connection and see if the trip has changed. Also if there is any leak on the machine if the trip switch is a ELCB , which can trip with a ground/earth leak. If so check the outlet ground or use another plug point.
Apr 21, 2011 | Dishwashers
My dishwasher when switched on keeps throwing the trip switch
i had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Oct 09, 2007 | Indesit 24 in. D63 Free-standing...
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
