Question about Music
Need default password for advance setting of the megavision pro hdd multi karaoke jukebox mk8504
How do you set up for a simple pa system?
It Depends how many Channels you are wanting for a basic 2 deck set up using Cdj's you would want 4 channel 2 per deck 1 master out and 1 booth so you can hear it through your head phones but if you were doing Karaoke you would want 6 channels for 2 microphones all going 2 the master out. but it changes again if us software and controller because most software has an internal and external mix mode. Here is a video that might help
Sep 02, 2014 | Behringer EURORACK UB2442FX PRO Mixer
I have a Behringer B1 Microphone and a Behringer 1202 Mixer. I want to know how to connect both of these to my Yamaha Home Theater receiver so that I can sing karaokes from the computer, Please help
You'll need to connect both your PC and the Mic to the mixer, you'll need phantom power switched on at the mixer for the mic to work, you then take the two track out to the Aux input on the receiver.
Jan 30, 2014 | Behringer XENYX 1202 Premium 12-Input...
What preset effect number is best for karaoke?
Always use echo and reverb, or just reverb for inexperienced singers. If I remember right this is from effect 19 but this is a very inflexible set-up with no control over the effects, just presets. You'll need to listen and decide what is best. You may also try chorus as with a decent effects unit this can be very effective plus a bit of reverb and echo.
Different songs like different effects and we will chop and change even in a single track when live mixing professional acts.
Dec 26, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I picked up a vocopro karaoke machine at a yard sale and the echo makes a loud hum also i need a owners manual and remote where can i get help with this. model#890G thank you
Hello. For the manual and remote your best option is to search online. As far as the echo goes, this is just a cheap microphone with a cheap system. It will not go away unless you turn the volume down on the system. If you want to put good money down on a nice SHURE brand microphone it will definitly help with the echo, however it will not make the system any better.
Apr 17, 2011 | Vocopro DVD-Duet Multi-Format Karaoke...
I am a dj/kj i'm looking into purchasing a Acesonia 1000 but I have some reservations...
An observation is that the large music suppliers like Musicians Friend, Sameday music, and Guitar Center do not stock the Acesonic brand. As a professional you need to cover yourself should you have equipment failure so a good starting point is to investigate what is available as rental... also they tend to choose robust stuff for rental...
Also, if you are packing a 500GB hard drive as media, it needs to be handled with kid gloves...
Feb 04, 2011 | Ace Sonic Acesonic Kod-1000 Karaoke...
I have a Voco Pro Model DVD-Duet. The problem is when you put a cd in the little center knob is stuck down that keeps the cd on tract it looks as if someone has pushed it down and it want come back up so...
It is possible the carriage that the CD goes in does not lower onto the center hub rather than the hub being too low.
The carriages move by a small motor and often there is a belt that slips so carriage doesn't move. Replacing the belt is usually required.
Working on the CD drives is very tender fragile work so you should take this to a repair shop. Contact the manufacturer for a recommendation.
Feb 19, 2010 | Vocopro DVD-Duet Multi-Format Karaoke...
I need a schematic for the vocopro entertaner model no HKH000011
You might try emailing the service centers listed here and see if you can get lucky:http://www.vocopro.com/servicecenter.php
Jan 23, 2010 | Vocopro DVD-Duet Multi-Format Karaoke...
Music Logo
487 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
