Question about Vacuums
The drive dogs on my Jones sewing machine VX760 don't feed the material because they are below the foot plate.
4 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: I have a Janome Memory
You have ended up in the Vacuum cleaner section, but if you look in your User Manual on page 71 you will be able to read about how this is achieved...feeddog switch, then rotate hanwheel one full revolution to re-engage.
Cheers Bargain Box
Posted on Apr 08, 2011
  • 1768 Answers
SOURCE: Singer Stylist 457 has feed
1. make sure you have the correct needle plate in place for the "foot" you are using. There is a "general purpose' plate and then other that may not work with the "foot" you utilize.
2. make sure the bobbin is place in the bobbin socket properly.
3. Make sure the needle is inserted properly.
4. Check if you have to oil the cam assembly
Remove lint of fluff from exposed parts.
With a soft cloth,clean
1. Tension discs, take-up lever, and Thread guides.
2. Pressure bar and needle bar
3. Bobbin case. (If there is an excessive amount of lint in the area, remove the bobbin case for cleaning.
4. Remove face plate as instructed on page 62 of the manual and clean area behind it with a lint brush.
5.Remove needle plate as instructed on page 8 of the manual, and using brush, clean the rotating hook area under the needplate and side plate
6. Your machine require no oiling under normal conditions.
7. check your "Tension dial" to see if you have the proper tension.
8.
Posted on Apr 10, 2011
  • 1833 Answers
SOURCE: Just got white E-Z sew
The thread should be going counter clockwise. You probably have to pullabout 3 inches of thread out of the bobbin to be safe, and pull that up overthe plate and drape to the left. Then pull about 5or 6 inches of thread outfrom the needle. Try holding that thread somewhat taught and lower your needleup and down with your side dial and see if it finally loops the bobbin thread. Hope this works.
Posted on Jun 25, 2011
Feed dogs are not advancing material
check the position of the forward / reverse lever or knob
this indicates that the selection is in the middle
check for a broken drive belt in the head of the machine not driving the bobbin shaft
Nov 08, 2015 | SewShop.com Singer Model 513 Instruction...
HOW TO INSTALL NEEDLE PLATE ON SINGER 30518 SEWING MACHINE?
Hey, i just took the needle plate out to clean and i cant put it back. same model 30518, somebody can help? :(
Oct 27, 2014 | SewShop.com Singer Model 30518 Instruction...
My machine flashes C4 when i want to sew
Clean the bobbin case area thoroughly, and probably the feed dogs, too. Start all seams by holding the top and bobbin thread ends together behind the presser foot for the first few stitches. If you have lost your manual, pick up a new one, free, at http://www.singerco.com
Mar 21, 2014 | Singer 7256 Fashion Mate Sewing Machine
Feed dogs where is switch
You should post this in the sewing machine section. It is posted in the vacuum section
Jan 25, 2014 | SewShop.com Singer Model 6233 Instruction...
Feed dogs don't work!
Many of the older machines had a long geared belt that operated the feed dogs. Turn the machine upside down, take the bottom off and check. If there's a belt there, check it for tautness and for useability. If there is a belt, take it off and try the sewing machine repair shops in Kazoo on S. Westnedge for a replacement.
Oct 23, 2013 | Singer CG590 RBFree$30CarVac*18Stitch...
What year is my singer sewing machine? AH251729? how do I purchase parts for it, like the zig zag attachment?
The Singer vintage machine site indicates that the AH251729 was made in 1947 in Elizabeth, NJ. For details see http://www.singermachines.co.uk/faq/tell-sewing-machine-age-from-two-letter-serial-number/ .
Look on the front of your sewing machine and locate the model number of the machine. Go to http://www.singerco.com/support/replacement-parts-chart and locate your model number. (Use the drop down menu and locate the group. Press Go and then find the pdf with the correct model parts list.) You can look up the exact part number and order them from the Singer Service Center online.
Alternatively, you may be able to find them at any Singer Authorized retailer. Just look at your machine and determine the type of shank that connects foot to the machine. (High Shank and Slant are common Singer foot designs on older machines.) Get a zigzag foot for Singer machines with that design. (If they don't have that, you can probably get a current foot and an adapter. We got an overedge foot and the high slant foot adapter for my Singer sewing machine (purchased in 1969) in the 1980s.)
I hope this helps.
(Singer parts are generally available. I saw throat plates for some Featherweight machines this morning at a quilt show.)
Sep 04, 2011 | Singer Vacuums
HAVING A PROBLEM WITH MACHINE JAMMING UP AROUND BOBBIN AREA WHEN TRYING TO FREEHAND EMBROIDER IT STARTS OFF OK THEN QUICKLY JAMS UP HAVE ADJUSTED THE FOOTPLATE SO THERE ARE NO TEETH
Check your tension first by sewing a wide zig zag stitch. Does the top of the stitch and the bottom look identical? The sides of the stitch should look like a hole where the thread disappears to the other side, with no extra thread from the other side coming through. It also should lie flat and not be puckering in the middle. When it looks identical and no puckering the tension is correct. Use the same type of material and thread you will be using for the embordery. The bottom side of the stitch is effected by the TOP tension. The top side of the stitch by the BOTTOM tension.
Are you stretching the material you're hand embordering with a hoop?
The dog feed needs to be totally down and if your machine has an adjustment the tension on the foot should be lessened too. (not all machines allow for that adjustment).
Last but not least make sure you have the right needle for the job and material.
Jamming up in the bobbin area would most likely be from the top tension being too loose but also make sure the material isn't getting pulled down in by stretching it with an embordery hoop. Do use a presser foot... a wide clear one is best.
Apr 26, 2011 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
