Question about Hotpoint Aquarius WF215 Front Load Washer
Hotpoint Aquarius WF310 Hi I have a problem with the machines lights all flashing very faintly in the middle of a cycle, I switch it off at the mains, but they still flash for around 10 seconds??? Is this dangerous please? Also it washes ok, spins and stops but the noise is very bad and the drum seems to make the machine jump out every so often. I'd be grateful for any help please. Thank you.
    Problem Solver:
  • 15 Answers
I have flashing lights problem not dangerous. bearings may b gone or going
Posted on Mar 23, 2011
Door lock light not coming on and cycle not starting on my Aquarius WF310
I fixed mine by ordering a $49.00 door switch # 34001265 from eBay. remove door seal ,3 screws and now I am washing again. saves $80.00 service $79.00 local parts.
Jul 26, 2014 | Hotpoint Washing Machines
The door lock light will not come on our hotpoint aquarius WF310 and the machine will not start
Un-plug the machine, remove the spring that hold the door seal look in at the door lock switch, usually it is broken . order the door lock switch for $50.00 MY eBay. p/n 34001265
Hi there, My washing machine is hotpoint WTL500
My washing machine runs for 10 minutes then all the lights start flashing also there's water in the drum, I've drain the water twice but it does the same thing.
Any idea what's going on there pls.
Aug 11, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi - reference our washing machine WF000G - the energy save light is flashing along with the on/off button and the machine wont run its cycle - can u help?
Do a search on Google using 'diagnostics, hotpoint, flashing lights'. There must be a manual which will identify what this fault is
Dec 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Flashing lights and machine not entering washing cycle.
you may have a circuit board damaged, check for the pump and door lock. may be one of this 3.
Nov 13, 2008 | Hotpoint Aquarius WD640 Front Load...
All Lights Flashing on Hotoint Aquarious WF310 Washing Machine
Means that the heat sensor is broken.
Replace that and it should fix your problem
May 09, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF215 Front Load Washer Logo
397 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
