Question about Rancilio Silvia Espresso Machine
My Silvia machine is only about 1.5 years old and I have already replaced the boiler. I went to turn it on and it shorts the electricity in the kitchen ... the power just jumps every time I attempt to turn it on. I have tried the reset button inside( the Red pin. It doesn't need to be pushed in). Help?!
    President:
  • 1,618 Answers
When you replaced the boiler did you fill it before turning the machine on? If no then the element could be damaged.
Posted on Sep 23, 2011
Low steam pressure
descale the heating elements with vinnegar.
Mar 20, 2014 | Rancilio Silvia Espresso Machine
My silvia is less than 2 years old. Yesterday I let the steam switch on and forgot to turn it off after steaming. It was on for about two hours. Then it won't heat up either. Should I get new part
On the happy side, if you tried to re-heat the boiler and found this problem straight after it failed, the thermostat may still re-set once the unit cooled down. So leave it a day and try again. Alternatively, it could be a burnt out fuse or on the less happy side, a burnt out boiler.
If no lights come on its a failed fuse. But if everything else is normal but it still wont heat, the best option is to take it for a service to a qualified technician as it may be that the boiler was damaged.
Jul 13, 2012 | Rancilio Silvia Espresso Machine
My 6 to 7 year old Silvia stopper making steam today. Do I need to send it out and where or is a diy
If it comes up to brew temperature, you have to replace the steam thermostat, which is a DIY. There are 2 thermostats on top of the boiler. The one with the red dot is the brew thermostat, so the other one is the one you need to replace.
Aug 22, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Boiler light never goes off
Hi
If you have an ohms meter, do a check of the element in the boiler. The reading should be between 12 and 16 ohms. If you don't have any reading, you have a bad element and need to replace the boiler.
Jul 14, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Keeps tripping the Breaker
Usually when that happens there is a problem with the element in the boiler.
Jul 06, 2009 | Rancilio Silvia Espresso Machine
Rancilio silvia
Youve probably run your boiler dry and blown your thermostat/s. You'll need to have them replaced. You may get away with only having to replace one. It will cost about $80(AUS) to have done or less if you source the parts and do it yourself (not recommended).
Sep 08, 2007 | Rancilio Silvia Espresso Machine
Rancillio Silvia Steaming problem
Sounds like your Rancilio needs a service, this problem could be caused by the boiler not working correctly, possibly a leak from the boiler or a valve malfunction causing a drop in pressure.
Aug 02, 2006 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
