Question about Rancilio Silvia Espresso Machine
My machine is only about 1.5 years old and I have already replaced the boiler. I went to turn it on and it shorts the electricity in the kitchen ... the power just jumps every time I attempt to turn it on. I have tried the reset button inside( the Red pin. It doesn't need to be pushed in). Help?!
    Problem Solver:
  • 16 Answers
The only time I have seen this was with a defective boiler. Be sure there are no bare wires touching one another or touching the machine.
Posted on Aug 04, 2011
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: My Silvia machine is only about 1.5 years old and
When you replaced the boiler did you fill it before turning the machine on? If no then the element could be damaged.
Posted on Sep 23, 2011
I have a Bosch Worcester 24i Combi boiler which is 4 years old, last year had problems with boiler not always coming on and had the circuit board replaced, now the boiler does not come on at all and the...
hello!
Thats is the problem of the boiler when the circuit had already replaced this will work but it cause another problems on the timer.
Please try unplug the boiler and replug it again to reset the setting . If not solve then maybe you should examine again the circuit board there might some parts that is not functioning.
melnavz
Mar 14, 2008 | Kitchen Ranges
I have a Kitchen Aid dishwasher that is 12 years old. The "clean" light on the control panel is on and the machine won't start it's cycle. Can I reset the control panel?
Hello Lisa. Go to your electrical panel for your home or apartment and turn off the circuit to the dishwasher for two full minutes. Check to be sure that you have turned off the correct circuit by looking to see that the "clean" light is off. After two full minutes turn the circuit back on. This alone may reset the machine and the control panel.
If it does not, then you will have a decision to making regarding repair VS replace. I always make this recommendation to my customers with any appliance over 5 years old. Replace it. In this instance, the new dishwashers use much less water, much less electricity, are much quieter, and they do a much better job. The advancements in dishwasher technology and design have been remarkable in the past three years. Joe
Nov 18, 2010 | Kitchen Ranges
I cleaned my GE model JBP66D range that is only a year old and 6 hours later I went to turn the oven on and heard a click and then the power went off. It tripped the breaker and when my husband went to...
Best thing you can do is call GE at 1-800-626-2000 and tell them what happened. Some of these ranges were covered by a recall for that very reason, but even if it isn't, complain loud enough, they;ll fix it.
Oct 24, 2017 | GE JBP66 Electric Kitchen Range
I have Saeco Vienna digital coffee machine already for 7 years. It was working fine but now I have problems. Only small amount of water/coffee goes to the cup and rest (clear water) goes to the tray and...
Hi
You boiler is leaking. You need to replace the boiler. sorry. Your water hardness might be set to low if you have been descaling when it tells you to. Boilers usually last 7 to 10 years, but need to be replaced. If you need one let me know. I have some new and rebuilt boilers for that machine.
Mar 08, 2010 | Saeco Vienna Digital Coffee Maker,...
Problems with Maytag MER6772 Gemini Electric Kitchen Range
may tag gives 5yer worenty if not still under worant get rid of it
Apr 05, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Frigitaire gas range, elect. oven ..."or"..displayed and control
Check all circuits in the range for a short to ground and correct the short..
Your electronic controlis fried.
Power surges are electronic controls worst enemy.
Replace your electrinic control.
Feb 11, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Saeco aroma
The boiler is broken, you have short circiute in the boiler
Jun 19, 2008 | Saeco Aroma Espresso Machine
Maytag Gemini MER6772 keypad/ovens not working
I had same problem, error code F 1-8, shorted keypad. I was so frustrated I went ahead and tore it apart. There was a surprising amount of gunk and moisture between the plastic face and the actual contacts. I cleaned it up and let it dry out. It worked OK for a while, but the seal is not good, and moisture from baking is still getting into it. When it goes bad again, I'm going to take off the plastic face and just press the sensors with a pencil eraser. I'll probably replace the range within the year. No way I'm paying $385 for new pad + installation on 10 year old stove.
Dec 23, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Rancilio Silvia Espresso Machine Logo
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
