Question about GPS
2006 kia Amanti with check engine light at 111,940 miles; 320 code checks that the ignition failure sensor is the problem per local mechanic but he doesn't know if this will solve the problem... is this a legit problem and will it affect anything if gone unfixed or is this a simple fix replacement part? will this fix the problem or will other sensors be related to this as previous email stated Cam sensors etc...or other related areas? I hope I didn't purchase a Lemon
  • jack_knox Mar 23, 2011
    thanks, didn't want to go through swapping out parts, Labor costs and down time driving car back and forth to shop that's why I wanted to check to see if anyone had this previous problem and how they fixed it..The crankshaft position sensor or the speed sensor sound logical but could it also be a bad connection or connector...I didn't want to take to dealer and get overcharged or given the run-a-round bt that also is the most logical place to have it checked and diagnostically checked...I have checked for recalls but none to be found and not too much info on this...one guy suggestions remove the failure sensor plug and put some grease type stuff in the connector for a better connectivity...any other suggestions and does anyone have a repair manual out yet on these Kia's? Thanks, Jack
    Top Expert:
  • GPS Master
  • 81,400 Answers
Hello
1st let me say that "320" is not a valid code, I will assume the actual code is "P0320" based on what was replaced. There is no one answer to this code, it needs the attention of a factory trained electronic engine control diagnostic technican. One code does not make this a Lemon, you just need the right person to get it fixed and pin down the actual cause of the problem. Below is what is the possible solutions as well as what causes the code to set in the engine controls computer.
P0320 2006 KIA Ignition/Distributor Engine Speed Input Circuit Problem/Fault
Symtoms of this fault code:
Engine Light ON (or Service Engine Soon Warning Light)
- Lack/Loss of Power
- The engine may be harder to start
- The engine may stumble or stall
Possible causes - Ignition/Distributor engine speed sensor harness circuit is open or shorted
- Ignition/Distributor engine speed sensor poor electrical connection
- Faulty Ignition/Distributor engine speed sensor (this is among the common causes of this fault code)
- Engine Control Module (ECM) (doubtful this is the problem) Fault P0320 2006 KIA Description Ignition failure sensor is used to check whether the spark ignition is occurred correctly or not and also used to tachometer drive. The sensor monitors the voltage difference between a resistance which is on the battery circuit for ignition coil. When the ignition coil works properly, the electric current through the resistance is detected as voltage drop. This is confirmed for every ignition event with the crankshaft sensor and the camshaft sensor. If ECM detects a malfunction, no ignition is possible, so the engine would not start. If there is no ignition signal for a predetermined cycle for one or two ignition coils, an ignition coil circuit failure exists. As you can see the Ignition failure sensor is likely not the problem, it is just picking up on a problem occurring in the ignition system. My advice is seek out a specialist on KIA electronics, this may be the dealer.
Posted on Mar 23, 2011
  • 2 more comments
  • Marvin
    Marvin Mar 23, 2011
    After considerable research on the way this code gets generated in the system I have decided that my best quests without testing the car first would be the CRANKSHAFT POSITION SENSOR. I recommend your mechanic replace this part, it is located on the front of the engine and is the electronic equivalent of the old points in pre electronic ignition cars and trucks.
  • Marvin
    Marvin Mar 23, 2011
    Here is a picture part number and price I show for the Crankshaft position sensor, it should not take more than 1 hour to replace.
    AIRTEX / WELLS Part # 5S5695 http://www.rockauto.com/catalog/moreinfo...', '3672', 'toolbar=yes,location=yes,directories=yes,status=yes,menubar=yes,scrollbars=yes,resizable=yes')"> $91.79 [ source: www.rockauto.com ]
  • Marvin
    Marvin Mar 23, 2011
    Last comment should read "best Guess" not Guest.
  • Marvin
    Marvin Mar 23, 2011
    1st off, a live data scanner tool needs to be hooked up to watch the crankshaft sensors output, this needs to be watched and evaluated by a well trained KIA technican, this type of work is the most demanding and the hardest to learn, I've been doing it for 35 years and still don't have all the answers. I have given you suggestions based on my knowledge of electronic control system. I do not think the failure sensor is the problem, and for goodness sake don't put any grease on it, that will play havoc with the signal, what kind of mechanic told you this? A very young one I suspect. On the repair manuals, you can access all the factory repair manuals and service bulletins for a yearly subscription fee of about $40 at this web site.
    www.alldatdiy.com
How many catalytic converters on a 2006 Kia Amanti ?
If you have a v 6 - engine it should have two at the exhaust manifold and one down stream .in some cases the up stream converter will brake up and cause the down stream converter to clog up.if your state has emissions laws you will have to replace them. In S.C. we can bypass the up stream . but you might have a check engine light
Dec 21, 2014 | 2006 Kia Amanti
Kia Amanti Ignition failure sensor
Code p0320 refers to crank shaft position (CKP) sensor/engine speed RPM sensor-circuit malfunction===causes---wiring CKP/RPM sensor ---ECM. Get your hands on an aftermarket workshop manual for the car and you should be able to replace the items
Dec 27, 2013 | Kia Amanti Cars & Trucks
Mysterious Electrical Problem
93k is getting close to timing belt replacement. Check engine light comes on when getting close to 90 - 100k. Timing belt needs to be replaced every 90 - 100ks.
Aug 14, 2013 | 2004 Kia Amanti
Code p0320
Code 320 is for a problem with the ignition system including the circuit for the tachometer. Generally speaking the problem could be anything in the ignition system including the crank or cam sensors.
The ignition system would need to be checked out to pinpoint the actual problem.
May 16, 2013 | 2004 Kia Amanti
2006 Kia Optima LX V-6 Engine light flashing engine running rough
A flashing check engine light means FIX IT NOW! It probably has a dead cylinder (most likely an igniton issue).Most likely,the PCM has figured out which cylinder it is aand turned off the fuel injector to it.You can get a cheap,basic code scanner(mine was 50 bucks at Harbor Freight Tools,made by Cen-Tech).It can read the code and has a book to tell you what the code means.If you find the cylinder with the misfire and correct the problem,you have to clear the code to restore fuel to that cylinder(this cheap tool does that,too).
Apr 14, 2012 | 2006 Kia Amanti
My rpm gauge doesn't work on the 2006 Kia amanti and the check engine light is staying on
I have a 2006 kia amanti and engine light was on code said crank shaft sensor So I changed it put all together now code comes up P0320....Ignition/Distributor Engine Speed Input Circuit ?? rpm gauge don't work anymore
Mar 18, 2012 | 2006 Kia Amanti
Check engine light came on at 41000 miles on 2006 kia optima
go to service station for ecu scan, autozone do it free!! here apear what is the problem
Jun 01, 2010 | 2006 Kia Amanti
My check engine light keeps coming on on my 2004 kia optima lx, 4 cylinder dohc, a little over 92000 miles on it. I had the codes checked and got this result: Code P0320 definition: ignition/distributor...
Check with the place that checked the codes for you. Maybe they can test the IG sensor for you. That might help. Otherwise check all the connections relating to the sensor.
Mar 15, 2010 | 2004 Kia Optima
Engine Check Light - 2006 KIA Optima
Hi
Before you turn out the light you should have a code read carried out just to make sure nothing sinister is going on with the management system.
If the car is running ok then the code will probably either pertian to the O2 sensor, the EVAP system, or a drop in catalytic efficiency, but this isn't set in stone, just the most popular scenarios.
Very best regards
Geordie
Jun 13, 2008 | 2006 Kia Amanti
GPS Logo
813 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
