Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
I have a KitchenAid Superba KSRG25FKSS which intermittently leaks water from the dispenser. The filter is fine, the lines are bled. Someone told me that there is a switch in the back of the fridge that can be replaced? Could you advise what could be and what I could do to fix this? Thank you.
  • 42 Answers
They are probably referring to the water fill valve. The valve will have two solenoids on it. The water dispenser activates one of these solenoids to allow water to flow to the dispenser. Fill valves can let water through even when the solenoid is not powered up. This usually happens after a long time of use though. The part number to that valve is 4389177. Hope this helps.
Posted on Mar 23, 2011
  • dbartiromo Mar 23, 2011
    Thank you. I will give it a try. What are they referring to when they note a micro switch in the front dispenser area?
  • RaneyAPPL Mar 24, 2011
    The micro switch is what the paddel activates. I doubt seriously if that would be the problem.
Water dispenser leaks
Refrigerator Water Dispenser Leaks?
Refrigerator Water Dispenser Leaks show that the refrigerator's water system has a problem. To fix this problem, open the filter compartment and pull out the filter and push it back in so that it is secure in place. Push compartment cover until it clicks.
try to check this video.
May 13, 2014 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser on fridge not working - water pressure fine, could the line be frozen and why would that start happening all of a sudden?
Check to see if the water reservoir in the bottom of the frig is frozen. If it is, you will need to turn the frig temp down.
Dec 04, 2012 | Refrigerators
I have a Kitchenaid side by side refridgerator and is very slow in dispensing the water.
You need a new filter or your house pressure is low or your water supply line is restricted
Mar 24, 2011 | KitchenAid Superba Architect KSCS25INSS...
The water dispenser stopped working but the ice dispenser still works just fine on my KitchenAid Superba KSRG25QFB side by side
First Question, Have you changed the water filter???needs to be done every 6months. dirty water filter can keep water from flowing through system......also nasty to drink.........
Jan 09, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Kitchenaid no water, but ice
first thing i would check here is my water resivoir, on these models it has a tendency to freeze,, hit the tank and upper line with a hair dryer for several minutes then give the water a try....
barring that it may be time to change your water filter even if the sensor has not picked it up yet
Oct 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
CLEANING WATER LINE?
replace the cartridge but when you do put a cap full of bleach in the filter housing .run the water for a while and this should clean any bacteria that you think might be in the line from the filter to the dispenser, be sure to run the water through the dispenser and dispell all the bleach
Oct 10, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
Water despensor stops every time filter need changing.
generally what happens is when the filter is removed, air enters the system and has to be bled off (in mechanics terms). generally if a glass is placed under the dispenser and dispense button is held for a minute or two, it will work as normal once the air is pushed out by the water.
clarkco
Apr 11, 2009 | KitchenAid Superba KSCS23IN Side by Side...
Water is dispening to slow
check for proper flow and pressure on water supply line
Feb 23, 2009 | KitchenAid Superba KSCS23IN Side by Side...
Drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Dec 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
138 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
