Question about Samsung CLP-315W Laser Color Printer
Need to adjust color profile. Owners' manual doesn't help.
    Genius:
  • 1,157 Answers
Hi Bekken,
For you to be able to adjust the color profile you need to use Adobe Photoshop and the icc profiles readily available. Your system has a current working ICC profile and it could be either Adobe RGB, SRGB, and if you are a specialist you can use Adobe RGB (1998). Here are some steps that you can apply to change the color profile.
1. First, make these changes in Photoshop.
2. Now, [Edit] then assign profile, ColourMatch RGB.
3. To print, go [File] [print] the printer profile should be Adobe RGB (1998).
--> for additional information please click the link below.
Profile usage
Hope it helps.
Thank you for using Fixya.
Posted on Mar 25, 2011
My ge profile kitchen range's timer is not loud enough to hear across room.does anyone know how to adjust it? also,how do adjust from 24 hr.clock to a 12 hr.clock?brenda
I don't think the sound level can be adjusted. I suggest looking up the owners manual and it should give you direction on the clock. The manual will also list if you can adjust volume. good luck
May 18, 2016 | GE Kitchen Ranges
I want to change my monitor colour temperature
When you use the Colors window to select colors for text or objects in a document, you can also assign a color profile to the document. Color profiles help ensure that the colors you see in the document onscreen match the colors in the document when it's printed or viewed on another computer.
To choose a color profile for a document:
  1. In your document, select the text or object whose color you want to change.
  2. Open the Colors window.
    In some applications, you can open the Colors window by choosing Format > Font > Show Colors or Format > Show Colors. In some applications, you can also click a button in the application's toolbar or a settings pane.
  3. Click the Color Sliders button.
  4. Choose a slider option from the pop-up menu.
  5. Drag the sliders or enter specific values to adjust the color.
  6. Click the colored box next to the pop-up menu and choose a profile from the list.
If you open your document and the colors appear in a different shade or hue than you expected, the application you're using might not recognize color profiles. Try using the generic color profiles instead.
In some cases, an application may not open documents that use non-generic color profiles.
You can create your own custom color profiles using ColorSync Utility. For more information, open ColorSync Utility and choose Help > ColorSync Utility Help.
Jan 08, 2013 | Apple Mac OS X 1063 Snow Leopard Family...
I have colour problems with my webcam! it doesn't show the colours properly, for instance, my blue shirt appears purple.
you might try to adjust your color profile through windows control panel,display. or when you open the control panel search for color profile
Dec 01, 2012 | A4tech A4-PK333MB WEBCAM 1.3M
KP-46WT500 46 in. Rear Projection HDTV-Ready Television convergance adjustment
Try using the MENU button on your remote control to go into the TV picture settings menu. Change the mode to NATURAL, You can also try to manually adjust the color in the COLOR SETTINGS mode.
If that doesn't work, check out the handy troubleshooting chart in TV color problems and see if another solution will work. I hope this helps!
Sep 13, 2012 | Sony KP-46WT500 46" Rear Projection...
I have Compaq d325 Microtower AMD athlon XP 2800+ 2.08GHz 256MB 40GB CDRW NIC XPP. I want to use a Haier HL32R as my monitor, but it doesn't seem to want to work. I tried using a VGA connector between...
Hi!
Using the VGA connector is OK. But to get it work, please be sure that the video settings on your computer are adjusted properly:
The resolution of your HL32R is only 1366 x 768. This is the MAX resolution you have to set on your PC. You can also adjust the refresh rate to 60Hz.
Please let me know if it helped.
Aug 26, 2011 | Haier HL32R 32 in. LCD TV
Leftside freezer door will not close properly? where to make adjustment?
Hi!!
Click on the following link for an Owners Manual, scroll down to the Installation Instructions section of the booklet. There you'll find all the step by step information to adjust the Freezer Door. http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60445.pdf
In case you need additional assistance, just post a comment.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 24, 2010 | GE Profile Arctica Stainless Steel Top...
Hansol710p 17"Monitor color adjustment problem
wich is factory colour profile from hansol 710p ? thanks in advance p.s. jovica.tasic@hotmail.com
Jul 25, 2009 | Hansol 710 P Monitor
Mitsubishi HP1080P WD73733
Was the set new? Color problems can be a bad light engine or a bad color wheel. Do you have the owners manual for this TV set? If Not i will try and leave you a link for one.
Feb 23, 2008 | Televison & Video
Sylvania Model 6420FF Television - How Do you Adjust Color?
Hit menu on your remote - click on picture - scroll to color
If you need a copy of your owners manual please click here
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Oct 21, 2007 | Televison & Video
Samsung CLP-315W Laser Color Printer Logo
287 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
