Question about Troy Bilt Tb70ss Gas Trimmer
Pull cord broke for tb70ss - Troy Bilt Tb70ss Gas Trimmer
    President:
  • Troy Master
  • 1,545 Answers
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Post back if needed.
Posted on Mar 23, 2011
My pull rope broke on my tb70ss how to fix
U tube has all sorts of videos regarding restringing of broken starter cords.
Aug 21, 2016 | Garden
Replace pull cord
Replacing a pull cord is not easy. After you remove the shaft, then the drum cover, you are left with the drum and clutch. There is a screw in the center of the drum which has to come off. Then there is a the clutch which if not removed correctly will come apart on you. Only after both parts are remove can you get to the pull cord.
Oct 19, 2013 | Troy Bilt Tb70ss Gas Trimmer
Cannot get the housing off so that I can change the pull cord on my troy bilt tb70ss grass trimmer
If you are holding the unit where the drive cable goes in, there is a screw in there. It is a #15 or 20 TORX screwdriver. Take out the screw and it will allow you to get to the starting spool. Good luck...Lee
May 29, 2010 | Troy Bilt Tb70ss Gas Trimmer
I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Apr 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
Pull cord
try this site it may help its called pats small engines
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
115 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
