Question about Dryers
Hi, I have a bad knocking or rumbling sound when the dryer is on-- I think it could be something that the drum is rolling on? glides? or a slipped belt--? There is a 1-2 second hesitation in the noise when the dryer starts up, if that is a clue. Anyway, I can't seem to get inside there for a look-- the exterior case looks like one piece, the back looks inaccessible, any help to get in there for a look? many thanks!
    Problem Solver:
  • 6 Answers
Look inside the dryer for a cracked drum, sometimes its easier to spot when you turn the dryer drum manually slowly with your hand. it should be in the back area depending on what brand of dryer you have. Good luck!
Posted on Mar 23, 2011
Why does it sound like a ball bearing rolling around?
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Apr 25, 2015 | Dryers
Constant loud squeaking
Squeaking is normally caused by a bad bearing or a slipping drum belt.
Feb 28, 2015 | Dryers
Rumbling grinding
DRYER MAKES NOISES.
The blower:
The bearings:
Feb 17, 2015 | Dryers
Why is my divinci 6030 receiver making loud rumble noise when I push the power on in the back of unit. I have nothing hooked up to it.
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Dec 17, 2014 | Dryers
Bosch WTA 3510 uc/13 FD 8203 compact dryer is very loud. Motor is okay. Just changed the main pully. Belts are okay. Still is a loud rumble when operating. Any ideas? Rear bearing appears to be ok
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Oct 09, 2014 | Dryers
My 13 year old Maytag Dryer rumbles to a start when you turn it on and rumbles to a stop. Sounds like the belt is slipping to me. Should I contact a repairman to replace it?
I would check the drum rollers and glides first, the other cause may be the idler assembly which is next to the motor, it keeps tension on the belt. Since you will have it apart you can check the belt for cracks and wear, if it looks good then I would not replace it. eBay is a cheap place to find dryer parts, here is a website on the rollers/glide you can go to the virtual repairman and it will help. I think it is a good site to troubleshoot just about anything you may have problems with, Good Luck Tim.
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Dec 18, 2010 | Maytag PYE4557A Dryer
Tub stopped turning, connot turn by hand either.
Dryers have a belt that turns the drum, I think dryer belt being broken or slipping badly, burn out motor, or worn support parts.
---Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it. ---You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it. ---Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Thanks..!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 06, 2010 | Maytag Dryers
Drum vibrates unit and makes a rumbling noise
sounds like the blower wheel is bad.the blower wheel is behind the duct that the lint filter slides into,when the wheel goes it makes a rumbling sound,also you could have worn glides that the drum rides on or a bad roller,you need to get in there and look but i'm sure it's worth repairing
Mar 29, 2010 | Amana DLE330RAW Electric Dryer
The dryer is making a loud noise when running. the drum is turning. almost sounds like something is rolling around under the drum.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
6565ggf
Feb 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
Apr 07, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
Top Dryers Experts
