Question about Garden
I HAVE AN HOMELITE UT-105062 XL. JUST STARTED TO LEAK GAS OUT OF WHAT LOOKS LIKE A VENT HOLE ALMOST AT TOP OF GAS TANK. AND I FILL TANK AND ALOT OF GAS COMES OUT ON ME , IF I TURN SAW ON SIDE TO CUT IT LOSES POWER . EVEN WHEN I FINALLY GET IT STARTED JUST CUTTING A LOG TO FIT IN FIRE PLACE IT BLOGS DOWN AND SOMETIMES STOP OR STALLS
  • 508 Answers
SOURCE: Primer bulb is part of the fuel cap.
http://www.upstateoutdoorpowerequipment.com/?gclid=CJrT2dXno5sCFQk_agodVn7zAg
GoodLuck!!!!
Posted on Jun 24, 2009
  • 4088 Answers
SOURCE: Homelite ut No. 10748 textron New sitting long
Is there bar oil in the tank? Oil pump and/or pickup tube in oil tank are usual suspects.
Posted on Jul 04, 2009
  • 4088 Answers
SOURCE: Homelite XL, UT 10618-A, 14
Likely problem with oil pump or it's drive gear.
  • 583 Answers
SOURCE: I recently bought a 12
I dont know where the fuel is leaking from but i`ll make a guess and say the fuel lines are perished.NOW all you have to do is disassemble it taking note of where every thing goes and replace them ALL.... not hard just have a good look at where things go before pulling them apart , you will manage
Posted on Aug 25, 2009
dontbother10
  • 2220 Answers
SOURCE: When I pull the trigger to accelerate my saw it
I think you have a cracked fuel line.
I'd also try a different mechanic.
I have very good luck with Stihl for my Husqvarna. HTH
Lou
Posted on Oct 24, 2009
1997 GMC Jimmy started spewing gas fumes into garage after fill up, keeps doing it until it gets down to 1/2 tank of gas?
check for a leak in the gas tank above the 1/2 level it could have a pin hole. it could also be a bad vent valve on the tank or in the EVAP system that needs to be checked out.
Oct 05, 2014 | 1997 GMC Jimmy
Homelite textron 104664
Unfortunately it's almost impossible to repair a leaking gas tank on a saw
Feb 20, 2014 | Garden
On my homelite leaf blower, gas is leaking out at the cap when i hold the blower pointing down...there appears to be a breather hole in the middle of the cap where the leak is occuring...should that hole...
No, the hole shold be open. There is a check valve in the cap which, when working properly, allows the tank to vent (lets air in so fuel will flow to the carburetor) but prevents fuel from pouring out. I'd first give the cap a good cleaning to see if that stops the leak. If not, you'll need a replacement.
More info, let me know.
Charlie
Feb 13, 2011 | Homelite Garden
I have a homelite xl, UT# 10655- the chain oil seems to be leaking and coming out of the exhaust and continues to leak after shutting off the chainsaw. Any ideas on the possible cause?
Your saw is listed as an "XL Chain Saw UT-10655" here:
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
See the "Engine Internals" print. The oiler appears to above the clutch and driven by a pressurized tank. Venting the tank (opening the oil cap) may help help with weeping but only emptying the tank will stop it.
If no oil from engine oiler hole I suspect a failed hose or connection. Use the IPL to inspect and repair as needed.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please take extensive notes & some digital pictures will help during reassembly.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Feb 27, 2010 | Homelite Garden
Car will not start after refilling the gas tank on a 2003 Hyundai
sounds like you have a bad vent on your gas tank
next time try leaving your gas cap off after you fill and try and start then
if this works just drill a vent hole in the gas cap
or change the tank vent filter
Dec 31, 2009 | 2003 Hyundai Accent
I recently bought a 12" homelite xl textron chain saw @ yard sale. it runs good but leaks gas. it has a hole in top of gas tank, it looks like a factory drilled hole with nothing in it. is this hole for...
Aug 25, 2009 | Garden
Got a homelite ut 15039a (weedwacker with blade st 185)
You have the rong fuel tank for that model.Thats the return pipe its comming from so you can drill a hole if youwant but make sure its sealed properly.
Jul 11, 2009 | Homelite Mighty Lite Lawn Trimmer
Jun 29, 2009 | Homelite ZR10926 16 Chain Saw
Husqvarna 145 bt gas leak
the fuel line is cheaper to replace than the tank the most common problem with weed trimmers & blowers is the fuel lines will rot & leak if there is a small hole in the line on top of the tank it will poor out if i can futher help e-mail me @ wadembly@aol.com thanks , wade
Jun 08, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
