Question about Thorens Audio Players & Recorders
I HAVE A THORENS TD 125 MK11 AND THE BELT KEEPS SLIPPING OFF, I REPLACED THE BELT AND THIS STILL CONTINUES ARE THE BELTS OLD? OR THE SPINDLE ON THE MOTOR SHAFT NOT WORKING
  • 3,018 Answers
Couple things to do here - First turn your platter upside down on a towel placed on a hard surface.
  1. Clean the motor pulley and the inner platter real good with some rubbing alcohol and some Q-tips. Be sure to let them dry.
  2. Now then wet your fingers with some water and just barely wet the belt with your fingers. Don't soak it, just enough to coat the belt with baby powder.
  3. Put the belt in a baggy and add some baby powered and shake it up real good till the belt is coated.
  4. Take the belt out of the baggy and shake the excess off. This is an old trick that will help the belt grab real well.
  5. Now you put that belt on and and watch the pulley and belt when it starts to spin.
  6. See if the belt slips now.
  7. If it does there is a little spring adjustment on the mount for the pulley. You have to find just the right spot during adjustment. It may require a little trial and error but the things I listed will solve your problem
Regards, Tony
Posted on Mar 23, 2011
I have a Hoover upright windtunnel. The belt that spinns the brush keeps slipping from the spindle on the motor. How do i keep it on there?
for a temporary fix, double up a rubber band on the outer tip of the spindle. if the belt slips over that, it's stretched out too much. replace the belt
Feb 28, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
My Thorens TD150 MK2 Phono Turntable Motor will not run or spin with the belt on but will turn without the belt on.What is wrong.
First replace the 0.33 microfarrad capacitor take a 0.47 with the same or higher voltage of a good quality and lubricate the motor top and bottom spindle bearings
sintered bronze buses with a ceramic high quality lubricant spray tecflow or other brand .
The best is to disassemble the motor only the top bearing is never enough also to control the both bearings.
Dec 31, 2012 | Thorens Audio Players & Recorders
If you can turn the platter easily by hand, then so should the motor. You can also disconect the power leads to the motor and hook up a PP9 9 volt battery to it. If it\'s slow and easily stopped from rotating then there\'s nothing wrong with the power to the motor and the motor is bad!
Dec 31, 2012 | Audio Players & Recorders
Cannot remove clip around spindle to lift off platten to get to change drive belt of my Thorens TD170
Hello mervyn_u,
The clip is a snap ring and it is best to use a pair of snap ring pliers to remove it without damaging or stretching it. Many people use a flathead screwdriver to pry off the ring but, again, you risk damaging the ring. You can purchase an inexpensive pair of these at your local Sears or other hardware store. They are simple to use.
Jun 15, 2010 | Thorens TD-170 Turntable
Turntable belt drive keeps slipping off.
I have a Linn LP12. At least in the case of my turntable, that's just how you are supposed to use it (i.e. this is what the manual says). You could get a replacement belt f you like, but I would guess it will not make a difference - that is, I think you do not need a replacement belt.
However, in my case I don't have to be very careful about the start-up push on the turntable, just one tweak to get it rotating at about the right speed is enough in my case.
Mar 10, 2009 | Thorens Audio Players & Recorders
Thorens TD-124/II
Well, with a turntable that old, if it hasn't been restored it likely needs to be. Could be the power cord, the motor or the clutch.
Go to this web site for more info:
http://www.soundfountain.com/amb/td124page.html
Jun 09, 2008 | Audio Players & Recorders
429 people viewed this question
Top Thorens Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Thorens Audio Player and Recorder Expert? Answer questions, earn points and help others
