Question about LG Dishwashers
The dishwasher has stop and is showing cd or ed not sure what does this mean Thank you
  • 55 Answers
Depending on which code is sounds like you have a drain issue. Remove the lower front panel to access to the drain motor. You could try to remove the pump and clean it out.
If water is in the base pan dry it up and determine where the water came from.
Appliance & Refrigerator Repair
Posted on Mar 23, 2011
Hi my dishwasher is showing h4/5/6, wht does this mean please?
Check this link here
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3714-beko-electronic-dishwasher-fault-codes
H4/5/6 pretty sure it means errors H4, H5, and H6 hope this helps
May 03, 2016 | Dishwashers
Error ed en am15
ed = Slow leak. Make sure the drain lever is closed, the standpipe is seated and the o-ring is clear.
Apr 25, 2015 | Hobart AM15T Dishwasher
Fagor dishwasher showing f6
Please check fault codes on page 70 in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
Sep 19, 2014 | Fagor Dishwashers
What does 'ED' mean on a danby air conditioner DAC5277EE?
That means it has a problem draining the condensate
Aug 09, 2014 | Danby Heating & Cooling
Have just tried to install a secondhand dishwasher which goes for about 5 mins and then shows UE. Could you please tell me how to fix this? Thank you Nancy
UE- means an unbalanced load in a washing machine.
le- means make sure water supply inlet hose is on. check inlet hose for any kinks or bends in the line
that could prevent the machine from filling properly, check and make sure the water supply is on
completely and not partially. check inlet filter for buildup of mineral deposits. clean filter with small
brush. make sure that machine can drain properly. good luck!
Apr 09, 2011 | LG Dishwashers
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
U1 Error and Washer Stops Working
"U1 error code" means the unit has failed to prime with water within 3 minutes. Its taking longer than expected to fill with water. Check the fill valve,it might be due to water supply problem, or the spray arm might not be in the exact position place.Check the above to fix this error code.
Thank you !!
Jun 22, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
NIKON SCAN IV ED
connect after PC start up
May 29, 2008 | Nikon Coolscan IV ED Film Scanner
Built in De Dietrich dishwasher
I suggest you get all your staff to search tirelessly for an answer, ChrissyJ!
Oct 02, 2007 | De Dietrich 24 in. DVF120J Built-in...
Dishwashers Logo
81 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
