Question about Dishwashers
I have a Bosch dishwasher SGV43A03 and the bottom spray arm doesnt spin. It is free to move by hand, is clean inside and has clean nozzles. The water pump is operating the top jet and top spray arm without any problem, but no water is being pumped into the bottom spray arm...Please help
  • 55 Answers
Hello this means the circulation pump would need to be replaced. You can purchase the part from the link below. Also there are several articles that explain how to work on Bosch dishwashers.
Appliance & Refrigerator Repair
Posted on Mar 23, 2011
I have a SGV43A03 dishwasher that is not cleaning properly, particularly on the top shelf. We have made sure that all filters and clean and have removed the top arm to ensure that there are no blockages. ...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Feb 21, 2011 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Bosch Exxcel Diswasher SGS43E08GB/43. Top spray bar won't spin. All arms, spray holes, ducts, filters, etc are clean and free from obstructions. Water comes out of the holes on the top bar but it won't...
try starting the washer, then opening to door and checking the water level in the bottom of the machine, as far as I know, there should be enough water there to disolve the tablet when it sits in the bottom. if not that much, bung in a few cupfulls and you should see the pressure dramatically increase!
Oct 28, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
The bottom spray arm of my bosch dishwasher will not spin. Nothing is blocking it, spins freely if you spin it by hand. We've tried resetting machine via control panel and also by circuit breaker, this...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Oct 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
Bottom spray arm not turning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
heatman101
rthd
Jun 09, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Jan 24, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Poor cleaning results in 4 year old dishwasher
  • check out all these for a way out
  • Check for adequate water level
  • Check the spray arms and spray tower
  • Check the water temperature
  • Check the detergent cup
  • Clean the fine particle filter
  • Check the inlet filter screens
  • Check the water pressure
  • Test the water inlet valve
  • Check the drain valve
  • Test the selector switch
  • Test the timer motor
  • Test the heating element
  • Test the bimetal terminal assembly
  • hope this helps appreciate by rating it
    Sep 18, 2008 | Bosch 24 in. SGV43A03 Built-In Dishwasher
    LG dishwasher bottom arm not spinning
    heatman101
    syte
    Aug 24, 2008 | LG 24 in. LD-12BW5 Free-standing...
    Water not going through spray arms
    1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
    Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
    Dishwashers Logo
    303 people viewed this question
    Top Dishwashers Experts
