Question about GE Washing Machines
New ge washer, turn on, not filling, goes right to washing stage. water and everything is on. its worked fine in the past. can it be off cycle, how do I fix
  • 97 Answers
maybe a blockage in the pressure switch pipe, this would tell your machine that there is enough water in and so goes into the wash cylce without actually filling. removing the pipe from the pressure switch end you should be able to blow down it and free any blockages.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
I have a GE Adora top-load washing machine. The washer fills up and overflows with water on all settings. Any ideas why?
  • You could have a bad level sensor or a pinched/severed/unattached vacuum hose which goes to the sensor device. The washer cannot determine how much water the tub is filling so the water keeps going in. I would check that the vacuum hose is simply not connected and that would be the easiest fix. The sensor device is usually located inside the control panel area and you can start there.
Dec 27, 2016 | GE Washing Machines
Ge wprb8050d
when it stops filling
you fill it with a jug of water to the right level
then see what happens
if it goes past rinse
have a look at the water valve it needs to be changed
Jan 21, 2014 | Washing Machines
Washer stops early cycle. In the first minute or two while it is filling with water it stops. If it gets past that stage it works fine.
gud day,,your washer has a little problem you must only adjust the washer timer,,you can fixed it by your self by opening the time at the back..tnx
Sep 09, 2009 | Kenmore 22642 Top Load Washer
Washer won't wash
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
May 30, 2009 | GE Washing Machines
GE WJSR1070A top loader wont aggitate.
You either have a bad timer, transmission, or the agitator is stripped on the splined shaft
Mar 05, 2009 | GE WJSR1070A Top Load Washer
Washer doesnt fill water but goes thru all cycles
After contemplating the issue, I decided that the machine "thought" it had filled. That led me to believe that the water level control was not working. I happened to have a control from an old washer that I could make fit. After replacing this control, I'm back in business. Everything is working fine although I now have only 3 water levels to chose from where I previously had 5. I hope this helps. Good luck. Mark
Dec 26, 2008 | Washing Machines
Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Sep 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
GE washer
replace the water inlet valve
Jun 10, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
