Question about Hitachi SDM/250RW 250 GB USB 2.0 Hard Drive
Hello when i plug in my sdm 250 hitachi my computer freeze
    Scholar:
  • 50 Answers
Hi, welcome to fixya.
It seems that the problem is hardware related.
Just in case, if the disc is brand new please try this:
Try plugging the HDD on a different USB port or plug it in to a different computer and see if this reproduces the problem. This will help you verify at first if it is the hard drive problem or the computer's (also you haven't mentioned what type of OS you are using on your computer but I will assume is windows for this solution).
If you can manage to get it to work, please transfer all important data from it to another external location and then re-format the drive (use NTFS). For instructions on how to do this, follow this link.
Thanks,
Regards from FixYa.
**Dont forget to rate how helpful the solution was**
Posted on Mar 23, 2011
Hatachi 250 rw software
Go to Hitachi website and download it.
Sep 08, 2012 | Hitachi SDM/250RW 250 GB USB 2.0 Hard...
SONY SDM S81R
hello sir,,
since there is a problem with the monitor..u have to contact the sony vendor ,
u can contact them in 800-326-9551
n also 888-476-6972..
thank you
have a great day
Jul 06, 2008 | Sony SDM-HS75 17" LCD Monitor
Hitachi SimpleDrive Mini-red wine USB 2.0 Portable Drive - 250GB SDM/250RW This external drive is not recognized by my pc- i'm running windows XP but have tried it on a Vista too, and also beeps once...
If you have tried it on two PCs with the same result, the hard drive is most likely defective. If so, the computer may recognize it being plugged in with a beep but will not recognize it at all as an accessible device.
One thing you can check is if the hard drive was never initialized, meaning that there is empty space but the empty space isn't configured for the operating system to recognize and use. To do this:
- Go to "Start" and "Run" and type in "diskmgmt.msc" and hit "Enter".
- A list will pop-up listing all hard drives on computer. Each row is a physical hard drive.
- The main hard drive for your computer should be listed as "Disk 0" and the local disk in it should be "C:".
- Assuming you have no other hard drive besides the external, the next row should be "Disk 1" and say "Unallocated", which means the hard drive was never initialized. In this case, right-click on it and select "Format". Click next through everything and the external HDD will be formatted so that Windows can recognize it.
- MAKE SURE NOT TO FORMAT LOCAL DISK C:!
- After that, the external HDD should be recognized fine and pull up in "My Computer".
Otherwise, if no other hard drive is listed, the external HDD is most likely defective and you will need to purchase a new one.
Feb 28, 2011 | Hitachi SDM/250RW 250 GB USB 2.0 Hard...
My computer is not recognize my external hard drive
sometimes wires get loose and do not make good conection make sure wires are making good contact to your hard drive. and to motherboard . first. and as always unplug pc first.
Jan 01, 2011 | Hitachi SDM/250RW 250 GB USB 2.0 Hard...
For some reason my Hitachi external hard drive is not showing up on my computer. I know that once i plug it in it should show up on My Computer but its not. What should I do??
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 13, 2010 | Hitachi SDM/250RW 250 GB USB 2.0 Hard...
I have several computers at home, and none og them can recognize this portable device. Hitachi 250 GB Mod: SDM/250RW
1) Power:
It may be the problem that occurs with a lot of USB powered devices jrherrer. Not enough power provided.
The USB cable plugged into the computer, provides signal wires for transferring information back, and forth, and also provides 5 Volts DC for power. (Two D cell flashlight batteries produce 3 Volts DC)
http://en.wikipedia.org/wiki/USB
[ Below shows the Signal pins, and the Voltage pins of the USB B Mini style connector, (Male), used to connect to the SimpleDrive Mini external harddrive,
Pin 1 is for the 5 Volts DC Positive (Wire color - Red)
Pin 2 is for the D- Signal (Wire color - White)
Pin 3 is for the D+ Signal (Wire color - Green)
Pin 4 is not connected. (Or sometimes joined to Pin 5 with a Resistor)
Pin 5 is for the Ground (Wire color - Black)
Just added info in case you wanted to know ]
From what I see the SDM/250RW has a USB port on the side, and a DC Power Jack, used for an AC adapter, also.
(Round port with a pin in the center)
http://www.hitachigst.com/tech/techlib.nsf/techdocs/0C876B7AB91B23988825773F006BEA02/$file/SD_Mini_DS_final.pdf
From what I see stated from Hitachi, and sellers on the 'net, the AC adapter may not be provided.
Many of those who provide a review state that both the USB cable, and the AC adapter is needed to provide enough power. Seems to be a power hungry external harddrive
It's a 2.5 Hitachi SATA laptop harddrive inside that external case. (The Harddrive is 2 and a half inches across in Width. Common size used for laptops)
When using an external device powered by a USB cable there are general guidelines to follow,
A) The USB cable should not be more than 2 feet in length
B) Connect the device directly to your computer, instead of through a hub, or other device, unless the USB hub has it's own power.
2) USB cable:
Could be a faulty USB cable, although I imagine you have tried different ones by now.
3) Interface Circuit Board:
The Hitachi SATA 2.5 harddrive inside the SImpleDrive Mini SDM/250RW, plugs into a small circuit board located inside that external case.
Components on the circuit board may be fried, or the Harddrive may have come loose from the interface.
Loose from the interface
To explain;
The back of the harddrive has connector pins sticking out.
The interface has socket holes which the pins insert into.
Faulty circuit board
The external case of the SimpleDrive Mini SDM/250RW can be carefully opened up, and the Hitachi SATA 2.5 harddrive extracted out.
Another inexpensive external case for a 2.5 SATA harddrive can be procured, and the Hitachi harddrive put in it.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2781
Nov 22, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
When I plug my my Hitachi SDM/205 250GB Simple Drive into the usb port a pop-up window appears and says that it needs to be reformatted. Have I lost my data?
Yes, but there are many recovery software that you can download from the internet.... so don't worry, try 4shared.com by searching Recover My Files which is very effective. Please note to format your HDD using Quick Format rather than Full Format.. Good luck..
Apr 20, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
My SOny SDM-S204 has no green in the computer display however, the monitor menu window is the correct color
Hello amellows, hi, check the video cable for loose connection, tighten the vga plug screw, try to wiggle the vga plug and see if there are changes on the display. As for the monitor menu, this is usually not affected, the colors are built in its onboard memory.
Mar 31, 2010 | Sony SDM-S204 (Black) 20.1" LCD Monitor
Simple tech 320gb HD
what do you mean by saying freeze up
pls give a clear discription
Nov 07, 2007 | Hitachi (14R9464-20PK) 250 GB Hard Drive
Hitachi SDM/250RW 250 GB USB 2.0 Hard Drive Logo
112 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
