My sylvania netbook won't boot to desktop it seems to be stuck on image drivers screen .. What do I do to start up it will just sit at this screen for hours
  • 1 more comment
  • EALLIE Mar 23, 2011
    I'm trying f8 but nothing happens still runs to loading image screen and stay it is windows ce
    It's actually stuck on loading device driver, as said prior f8 seems to have no response
  • EALLIE Mar 24, 2011
    I'm terribly sorry did not meen to hit no button
    Sergeant:
    Champion:
  • 239 Answers
I believe that this uses microsoft windows ce operating system. If this is similar to the other ms operating system then try tapping F8 as it starts. If you get to a new screen with options, select 'last known good configuration' and hopefully it should reset your system to a usable state
Posted on Mar 23, 2011
  • BobLC Mar 24, 2011
    Upon further investigation it appears that there is no way of easily resetting this as in XP and the other windows systems. There is more information on CE an microsoft
    http://support.microsoft.com/search/defa...
    Unfortunately I have no further knowledge of this system
A mannuel for a sylvania netbook
  1. Turn on the Netbook Start up the Netbook as usual, but instead of watching it load, immediately press the F2 key until the Setup Utility screen appears.
  2. Disable the Boot Booster Use the arrows to select the Boot tab. Click the Boot Booster option, then press Enter to disable it. Move to the last tab, then select Exit and Save Changes.
  3. Restart the Netbook Restart the Netbook, and press and hold F9 as the computer restarts until you see the loading screen. Click the "?" key to confirm when a message appears asking if you want to perform the operation.
  4. Wait as the process completes Do nothing as the restore process starts and completes. No human interaction is needed to finish the process. The computer reboots on its own and makes new configurations. The computer then automatically restarts again. At this point, the computer is now fully restored to its factory settings.
Jul 28, 2016 | Sylvania Synet7wic-bk-z2 Netbook
Why won't my sylvania netbook which runs WINDOWS CE..but it NEVER gets to the desktop page...what wrong?
I'm not familiar with Windows CE, but I have had similar problems with Windows 7 on laptops.
Try keeping the F8 key depressed when starting it up. The F8 key should allow you to start in 'safe mode'. I would imagine that the F8 'safe mode' is also to be found in Windows CE.
Keep pressing that F8 key as it powers up and hopefully it will present you with a screen that gives you a choice of 'safe mode' or network prompt. Choose 'safe mode'.
If your computer then starts in safe mode (it's just a minimum amount of drivers loaded to start the operating system) .. restart it again and see if it starts normally. You may have to 'play' and keep restarting it and pressing F8 ..
You can also change the boot up sequence as the computer starts. This is usually done by pressing the 'delete' key -or escape or f12 key (it varies from computer to computer)..
.. to take you to the bios settings. Change the boot order..if the dvd drive/usb is the first boot up device change it to hard drive as the first boot up device .. and see what happens.
It's almost as if the computer gets stuck in an endless cycle of 'trying to boot up' which is probably due to software conflict, for whatever reason.. some driver may not be loading to allow it to boot up correctly.
Jan 06, 2015 | Sylvania G-Netbook
Down load flash card
Oh dear. That sounds like a corrupt OS to me. You need an external USB DVD player to boot from. Power up your External DVD player. Insert your Windows OS disk in the player. Plug the USB in and power up the net book an press F2. Select boot from USB and choose repair OS when prompted.
Oct 25, 2013 | Sylvania G-Netbook
How can I get my ez book pc 7 to get past the ez book pc screen and get to the windows start screen?
HI
the last line that reported is what ?
1 - its may be you need to install windows again
2 - or repair the bootable
Nov 08, 2011 | Sylvania G-Netbook
I have a Windows CE Sylvania netbook that won't boot to the desktop. I can turn it on, but it seems to freeze right as it turns on. It shows the start up screen where it says "Loading OS Image...
One temporary solution is to remove the battery for a while until all the capacitors in the unit discharge. Upon replacing the battery, you get one good power up try. Notice that the date and time have reset. Once you turn off the unit and try to power it up again, the problem comes back and you must again remove the battery for a while. There may be a patch to fix the boot loader, but I have not found it yet.
Jun 15, 2011 | Computers & Internet
Frozen on loading screen saver, says sylvania loading o s image
when i power my sylvania 7 inch netbook on it says loading os image... it is frozen and i want to know how to fix the problem
Dec 25, 2010 | Sylvania G-Netbook
Net book with windows ce6.0 powers up , screen says windows ce and below that it says loading os image and the drivers will not start
Have you tried resetting the machine?
Turn the machine over, on the bottom about 1 inch to the right of the lower rightcorner of the data plate decal is a tiny hole labled RESET. You have to insert a small object (toothpick) into the hole and depress the switch and hold it for a few seconds, then try to allow it to boot again
Nov 27, 2010 | Sylvania G-Netbook
Computers & Internet Logo
674 people viewed this question
David Payne
David Payne
