Question about Altec Lansing ACS 43 Computer Speakers
I hear a continuous click, click, click when ever the volumn is about 50% up or higher
  • 27,725 Answers
The clicking noise could be the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your computer specifically from around your hard drive using a high powered suction vacuum cleaner or a fine air blower from a air compressor making sure there is no MOISTURE in the air lines then give the hard drive a firm tap on the side to free it up
test or replace all the leads that attach to your hard drive including electrical extensions IDE,SATA and the ones that attach from your (((motherboard to hard drive))) make sure the connections are securely seated and they are not bad/faulty and no dust built up or replace them
one bad lead can cause a computer lots of problems failing to detect reboot restarting on a cycle
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Posted on Mar 23, 2011
The volumn on my tab 8.9 is so low i can barely hear it. Volumn all way up 100%. How can 8 fix this?? Not on headphones just reg volumn.
Do you (or anyone else) use headphones on the Tab 8.9? If so, there might be dirt (or a foreign object) in the jack!
Apr 24, 2017 | Televison & Video
Unlock volume
The volume settings might be locked to '50'. If you have to release this, and to set it into 100%, have to enter its service mode option. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Service mode entry, adjust and exit procedure to many popular brand TVs are given in detail.
Oct 27, 2013 | Orion1934 19" TV
Samsung lcd volumn ok with dvd very low with tv only
What is it connected to when the volume is low? How is it connected
Feb 06, 2013 | Samsung LN-S3251D 32 in. LCD HDTV
No volumn controll on taskbar
Try and rigth click on the bar >propertys>customise enable hear or reset default setings
Dec 18, 2009 | Computers & Internet
Home theater
Check to make sure that your speakers' ohm rating matches the amp.
Also check every speaker connection carefully for stray strands, poor connections, etc.
Aug 22, 2008 | Electronics - Others
Mag. dtv converter box
the volumne is not the same as the old analog signal, the tv volumne has to be turned up much higher.
Jul 01, 2008 | Insignia Digital-to-Analog Converter for...
Volumn Control on my 36
I have to turn my volumn to 100 to hear it and the tv is 1 month old.
Mar 14, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Volumne control
Hi BCDC
Have you checked that the mute function has not been turned on. It provides a -50dB reduction in audio that may be producing you drama.
regards
Graeme
Mar 09, 2008 | Onkyo TX-SR601 Receiver
80 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
