My Royal VF880 shredder is not working. It is not shredding anymore and makes a very loud racket when you try to use it.
    Genius:
  • 1,218 Answers
Likely-hood is that you have taken the teeth out of a plastic drive gear inside...suggest you open it up to see what is broken then you can contact Royal at 1-800-524-0799 for parts assistance.
Posted on Mar 24, 2011
What kind of oil is used on the royal orca 9512x?
The shredder does not use oil. The noise probably relates to something jammed in the shredding mechanism or one or more damaged shredding elements.
Mar 01, 2015 | Royal Office Equipment & Supplies
I have a Royal Orca 9512x paper shredder. When I use it , it makes a very loud ,metallic squeeking sound. How can I correct this? It shreds fine. It's just noisey.
To fix this get some dry Graphite spray lube....
Spray graphite
Spray this on the cutters and sides of the cutters to lube the cutters and bearings....this will stop the noise...and prolong the life of the machine...
heatman101
Jun 18, 2011 | Royal 15MX Shredder
Tried to feed to much (thickness) through ... I have done this in the past but was able to remove jammed paper by going forward and back until jam was cleared ... this time however it seems the motor just...
This is the most common problem...people put TOO MUCH paper in shredders... the VF880 has plastic gears inside...having done this a number of times you may have broken the gears or stripped the "teeth" off the gears...open it up to see what damage has been done; once you know what is broken you can contact Royal for pricing and parts at 1-800-524-0799.
Dec 11, 2010 | Royal VF880 Shredder
The shredder developed a jam. I removed the bin and the top of the shredder. I removed the shredding mech. and removed the paper material. Reassembled the shredder. Shredder starts up when paper is...
Does the motor run??? even in reverse???
If the motor doeas not run at all it probably PCB. If the motor does run but the cutting mechanism does not turn then you probably have stripped/broken plastic gears... open and check,...contact Royal at 1-800-524-0799 for parts assistance.
Oct 27, 2010 | Royal VF880 Shredder
HT3SL doesn't feed, so it doesn't shred anymore. Powers on and the shredder makes sounds, but doesn't feed so no shredding.
If it sounds like the motor is running inside but nothing is driving then you have probably stripped gears inside...open it up and contact Royal for parts at 1-800-524-0799.
Oct 17, 2010 | Royal HT3SL Shredder
I have a Royal RL170MX shredder. It has started
Try putting some oil on a sheet of paper and then shredding the paper with oil on it.
If that dosn't fix it....take cover off....(with the unit unplugged.) and check plastic gears in drive train.
May 20, 2010 | Royal RL170MX Shredder
Royal RL170MX shredder is making a loud noise and won't take annything to shred.
You will have to open the top after you have unplugged it. Sounds like you might have taken out a gear or two... once you see what is broken give Royal a call at 1-800-524-0799 for parts and prices.
Feb 04, 2010 | Royal Office Equipment & Supplies
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
43 people viewed this question
k24674
jasbo
jasbo
