Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a 50 inch Philips Magnavox LCD TV. It worked fine till the power went out this morning. Everything came back on fine except for my TV. It still receives a signal but it has no picture and no sound. The picture will come on momentarily right before it shuts off so I know the bulb hasn't blown and I can see that it is still reacting to both the tv remote and the cable remote. I have tried rebooting the cable and unplugging the tv but it didn't help. How do I fix this?
  • Philips Master
  • 8,457 Answers
The projection bulb came on,but didn't stay on mean the bulb have problems,dosen't mean projection bulb it still good.First must replace a new projection bulb to make sure for the elimation for the projection bulb is the problems.These DLP tvs require new projection bulb every 1 1/2 or 2 years by watching the tv like 4 or 5 hours daily.So there no lost there for trying a new projection bulb alway can save it for later use.The secound could be the board that call the Ballast board have problems too.The Ballast board only job it is to ignite to the projection bulb and make it work.Replace the Ballast board too,if the tv new projection bulb react the same way.
Posted on Mar 23, 2011
Hi, I have a Magnavox 17MD255V/17 combo dvd-tv. Everything works fine except that the AC adaptor has a high-pitched whistle that continues while the tv is on. I tried unplugging from the the tv itself and...
TAKE THE AC ADAPTER APART. LOOK AT WHERE THE MANUFACTURER PUT HIS GLUE AND REDO IT CLEAR NIAL POLISH WORKS BETTER IT FLOWS UNDER THE PARTS BETTER. YOU CAN PLUG IT ALL IN WHEN ITS APART BUT MAKE SURE NOTHING CAN SHORT OUT. THIS WAY YOU CAN PINPOINT WHERE THE NOISE IS COMING FROM. OTHERWISE GLUE THE TRANSFORMER AND ANY SMALL FERRITE BEADS THESE SWITCHED MODE POWER SUPPLIES OPERATE AT HIGH FREQUENCIES AND LOOS PARTS CAN VIBRATE CAUSING THIS NOISE.
Dec 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My tv won't go past channel 17
Please try this free Philips Flat Panel Television owners manuals, user guides & how to ... A B C D E F G H I J K L M N O P Q R S T U V W X Y Z ... 13" LCD-TV PF7835 - Philips 20" LCD-TV Product Brochure ... 13MC3206 - Magnavox TV/DVD Combination ...
tv.manualsonline.com/manuals/mfg/philips/philips_flat_panel_televis... - 674k - Cached
Aug 21, 2009 | Philips Magnavox 20MS233S 20" TV
My digital comcast remote will do everything except change the channel on my magnavox TV. Volume/power control is fine. How can I fix it?
your tv needs to stay on the same channel for the cable box to work with the tv and you change the channel on the cable box not directly on the tv
Jun 12, 2009 | Philips Magnavox 20MC4304 20 in....
Magnavox MODEL # HD1905 C121 CHASSIS # 19E604-00AA SERIAL # 43468127 My Magnavox is stuck in a demo mode. I cannot turn the power on or off, and NONE of the buttons work, nor does the...
on the set press and hold the up and down volume buttons together till the tv turns off then press power to turn back on and everything should be fine
Jun 10, 2009 | Philips Magnavox 20MS3442 20" TV
Phillips magnavox
Could be an open internal fuse or power supply failure
Mar 18, 2017 | Philips Televison & Video
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Feb 19, 2009 | Philips Magnavox 27MS343S 27" TV
Screen on but black box in middle
okay i so happy i got the solution from another web page this what you do its the closed caption button on the remote or tv go to close caption and keep hit close caption until you see off that's it so simple
Sep 23, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Philips Magnavox 51MP392H Rear Projection TV
A sign that amps are going bad, right now you can check resistors in convergence board alongside the amps, check resistance to see if right.
Oct 08, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
165 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
