GE Spacemaker Washer and Dryer Electric Laundry Center Logo
Posted on Mar 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am looking for a manual for my GE spacemaker laundry
Anonymous
Level 3:
Brigadier General:
  • Master 6,277 Answers
  • Posted on Mar 23, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
6277
Questions
0
Helped
1025588
Points
20216
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Ge spacemaker laundry dryer does not heat
All dryers have states to control heat GE has a safty stat that is comon problem small round stat at top after removing lid check with ohms meter with wire unpluged if no continuity changed then check venting of dryer inside and out improper venting will cause dryer to over heat
heat element is the next go to same check but must take dryer apart more send model Number we can give you a diagram and location of everthing you will need
Does anyone have the schematics or manual for a GE Spacemaker WSM2420TCAWW Stackable Washer and Dryer.
I have this model with model#WSM2420TCAWW tag inside the dryer however the use and care guide and manual that came with it has Model#WSM2420S on it. Try searching this. If you dont have any luck I can send you a copy with your e-mail. Good luck dc
Ge Spacemaker Laundry the washer knob popped out
take knob off again and look at the stem where the knob goes does it have a round side and a flat side? if so the knob will have the same profile thats the way it goes on
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
